Catch Can WITH Valve Cover?
Originally Posted by CoolGuy094' timestamp='1398113348' post='23122927
If you're putting an AP2 valve cover on it (AP1's can use 04-05 valve covers) you can just use the stock crankcase vent port and put on an -AN adapter to the PCV valve threaded port. That way you won't have to worry about welding on -AN bungs. Its not as sexy, and you're restricted by the size of those two existing ports, but its been enough venting for me at 16 PSI supercharged.
I really like that setup from Radium, but it's a bit pricey IMO(if I were to go for the double can), then again, if I only have to run one can, it's not too bad, and like I said I don't have a trusted fabricator/welder here to modify the cover so this looks like a good option.
Sorry I don't have any good pictures; you can see the two lines coming from the VC over to the catch can over by the brake reservoir. This is when it still had the black filter on top.
Before I did this I used to have the issue with my dipstick always popping up, and once it was even so bad that my PCV valve blew out (AP1 valve cover style) and spewed oil all over the place. Ever since installing the catch can this way I've had zero problems with crankcase pressure. And the catch can does its job; emptied out a good amount of oil, gas, and foamy gross stuff the other day.
The catch can, fittings, and hose I probably have about $120 in. Probably half of that is the damn -AN fittings... those things aren't cheap! I did have to make my own little mounting bracket to mount where the throttle cable usually mounts.
Thanks again for all the info, today I found a place locally that's going to make me one for 45euro, can't beat that (unless you make it yourself.) Nothing to special, but it will do the job. I'll post pics when it is finished/installed. The place is called Alex Motorsports http://www.alexmotorsport.it/index.p...view=frontpage and it is near Naples in Maddaloni. They actually have my car right now for a headgasket/piston ring job
Just in case anyone else finds themselves here in Italy looking for a good local shop.
