CEL with codes P1361 & 1366
Old Oct 10, 2005 | 06:48 PM
mhollifi's Avatar
Default CEL with codes P1361 & 1366
I have a 2002 with a Vortech S/C. I had these codes come up but the CEL will come on for a while and then go out later and the car will also run well at times and not well at others corresponding with the CEL. I know that I need to check the wiring to the TDC sensors. I just tonight pulled the fuse to reset the computer and now the car will not start at all. I pumped the throttle pedal and then smelled the exhaust and no smell of fuel at all. Is that unusual? Could I have a failed fuel pump? The engine ran with no problems just before parking several days ago. Any help will be appreciated.
Old Oct 10, 2005 | 07:22 PM
Slows2k's Avatar
You need to check your connections to the timing controller. If you have an open connection the car will not start.
Old Oct 11, 2005 | 02:49 AM
mhollifi's Avatar
Thanks Slow. Just looked behind the side kickpanel and squeezed the press-on connector and now car starts and run ok.
superchrgds2k
Nov 17, 2017 11:16 AM
tej
Jun 6, 2015 08:31 AM
PrimePowerPro
May 28, 2015 07:12 PM
neptuner
Feb 26, 2008 04:05 AM
jojipoji
Nov 9, 2007 05:59 PM
