CEL - P1607 ?!?
Just received my code reader and pulled out this one
P1607, which is a "Engine Control Module ECM/Powertrain Control Module PCM Internal Circuit Malfunction"?
What could have caused this? I was probably doing around 80mph when it came up and having only just filled up with Tesco 99 instead of V power as usual a few miles earlier(night before in fact).
The car was fully warmed up and this was after a bit of minor VTEC action.. the car drove perfectly fine afterwards too but with the CEL illuminated...
I've cleared the code now and its not returned after a 6-7mile cruise and short 1-2mile blast..
Anyone else ever seen this code? could it be a faulty ECU? or just a one off glitch?
Any help/advice appreciated
Yeah you mentioned that about the fuel before, and fwiw I used Tesco 99 90% of the time in my 200SX and had absolute faith in it (iirc it was tested as having better resilience to det but with a slightly lower calorific value to V power)..
Just thought it was worth a mention as it was the only real change that was made
Originally Posted by MB,Dec 1 2009, 09:21 PM
Yep I seem to remember one like this.
Hoping it wasn't the one where there was corrosion in the wiring loom?
ouch.. better check my wiring! There was quite a bit of condensation in the cabin and a little moisture in the boot.. not had a moment to clean out the drains but passenger and drivers foot wells seem ok
yeah so, she popped another CEL this evening
This time P0420 Catalyst System Efficiency Below Threshold
Now normally this wouldn't worry me, what with the car being de-catted a few weeks ago... but two CELs (albeit different codes) in such close proximity?
Could there be an underlying problem? or is it pretty much a dead cert that its due to the decatting? The decat has a built in spacer for the o2 sensor, maybe i need to add an extra anti fowler for extra clearance?
