CEL no boost?
Old Jun 29, 2005 | 07:45 PM
  #21
Slows2k's Avatar
Either the belt is slipping,an air leak between the SC outlet and throttle body, or the SC isn't moving enough air to create boost. You'd have to call Vortech to price a new SC, or rebuild your current one.
Old Jun 29, 2005 | 08:44 PM
  #22
hackmac87's Avatar
yeah you have some type of air flow problem.map sensor wont cause no boost.
Old Jun 30, 2005 | 04:26 PM
  #23
twelv's Avatar
i did your test pressure thing and the turbine is moving air very hard got to take it on the road for a test after few adjustments to a loose seal.
Old Jun 30, 2005 | 05:21 PM
  #24
hackmac87's Avatar
you mean an boost hose was loose or a seal in the s/c was loose.
Old Jul 1, 2005 | 02:05 AM
  #25
twelv's Avatar
boost hose.
Old Jul 2, 2005 | 11:36 AM
  #26
twelv's Avatar
Still no boost!! it is the knock sensor I think they broke it when they installed my clutch. I am going to get to pay for it!!
Old Jul 2, 2005 | 12:02 PM
  #27
Slows2k's Avatar
The knock sensor isn't going to cause no boost, it will have a check engine light for the sensor code.
  #28
hackmac87's Avatar
you might have too unless you can prove it was broken during the install.
Old Jul 2, 2005 | 09:08 PM
  #29
twelv's Avatar
Ok then after all the trouble shooting I am going to have to say the belt is slipping.
Has to be everything is hooked up and everything is running like it is suppose to. The turbine is fine as far as I can tell it blows very hard.
Old Jul 2, 2005 | 09:09 PM
  #30
twelv's Avatar
yeah went by the shop they said no problem and ordered a new knock sensor for me.
