Change of plans
Old Jun 23, 2009 | 04:33 PM
m R g S r's Avatar
Default Change of plans
So I decided against trying to make my Ramhorn fit in my S. I welded some of the runners without first checking fitment in the car...big mistake on my part. So instead of cutting those apart and trying to make it work, I went back to the drawing board.
Here is what I came up with today. First design didn't leave enough room for a large downpipe, so i moved the first runner and now there is about 4-5" where it can squeeze in.
All tacked up:
Nice collector...should make good power
Bottom side....showing comparison of tight radius and laqrge radius 90deg elbows:
Another angle:
And here you can see I tried to tuck the first runner more to give clearance for the downpipe
Nice view
And this way I don't have to relocate my oil filter, which I hear a ton of people have leaking problems associated with that.
Hopefull I get a chance to weld it up soon and get the wastegate figured out. I have some ideas for that, I need to see which one fits best and will flow best.
Old Jun 23, 2009 | 04:36 PM
JoeyBalls's Avatar
nice
Old Jun 23, 2009 | 05:10 PM
jwa4378's Avatar
Are the runners equal length? That is huge in terms of helping the turbo spool.
John
Old Jun 23, 2009 | 05:16 PM
m R g S r's Avatar
no they're not.
It's pretty hard to do a topmount in the S and have true equal length runners.
Old Jun 23, 2009 | 05:53 PM
300sx's Avatar
Nice!
Old Jun 23, 2009 | 05:59 PM
THESPY's Avatar
sexy!
Old Jun 23, 2009 | 07:20 PM
jwa4378's Avatar
PFAB has done it.
Hopefully it all turns out good for you!
I will be following your progress!
John
Old Jun 23, 2009 | 07:45 PM
m R g S r's Avatar
Originally Posted by jwa4378,Jun 23 2009, 07:20 PM
PFAB has done it.
John
Not really. They are a bit closer to equal than mine, but like I said, I don't see how you would do a TRUE equal length top mount application with the frame sitting right there.
Old Jun 23, 2009 | 08:09 PM
tony1's Avatar
How's the transition from the collector to the turbine inlet? Looks pretty steep? Things like that will have a much bigger affect on things that 'true equal length'.
Old Jun 23, 2009 | 09:18 PM
m R g S r's Avatar
What do you mean by steep? The angle which the turbine flange is rotated on the collector?
