Changes AEM EMS 1012 to 1052
Old Mar 17, 2008 | 07:37 PM
AusS2000's Avatar
Default Changes AEM EMS 1012 to 1052
My AEM EMS 1012 has died and I need to purchase a 1052.
Generally the pinouts are the same but I know boost control moves to the D connector. What other differences are there?
Old Mar 17, 2008 | 08:58 PM
Soul Coughing's Avatar
the 1052 is smaller and can be located in the stock ecu position.
Old Mar 17, 2008 | 09:11 PM
AusS2000's Avatar
Umm, ok, I knew that.
I'm thinking more along the lines of things that might make it go pop if I just plug it in and go.
Old Mar 18, 2008 | 03:28 PM
duff0000's Avatar
Died..... Jeez How long were you running it for? Im looking into buying one and I dont really like hearing that.
Old Mar 18, 2008 | 04:18 PM
Fencer's Avatar
Are you selling your 1012 and WB gauge?
Old Mar 18, 2008 | 04:26 PM
AusS2000's Avatar
I've had it for about 4 years I think. But I bought it used.
Old Mar 18, 2008 | 04:27 PM
AusS2000's Avatar
Ummm, sure, however no guarantee.
It's dead. I'll see if AEM will repair and then may sell.
Old Mar 18, 2008 | 04:45 PM
AP1NYT's Avatar
Interested in knowing how much it would cost to fix the EMS.
Old Mar 19, 2008 | 05:31 PM
Fencer's Avatar
Even if AEM won't repair it I'd be interested.
Old Mar 22, 2008 | 10:08 PM
AusS2000's Avatar
Ok, I can conclude that the only physical change required is to change Boost Control from pin A11 to D16.
But now I have another problem. I got the 1052 and updated it to Firmware 1.19 and uploaded my map. Fired up the car and she started first go, but is only firing 3 cylinders.
I checked the coil packs, plugs and injectors and swapping them made no difference.
This sounds surprisingly like the issue I had that caused me to swap the engine but it can't be another cracked ring. The engine ran fine before the EMS died. I wonder if there is software differences in the EMS that mean injector 3 isn't being driven. I know that you use injector drivers #1, #2, #4 and #5.
I'll check it out tomorrow but if anyone has some insight it would be greatly appreciated.
