check engine light and car wont accelerate.
Disconnecting the battery does nothing to fix the problem, It only clears any codes stored in the PCM. The Stock PCM isn't the problem, It works just fine on stock applications, and with a properly functioning MAP clamp and timing controller form Vortech.
somewhat self serving input here, but this is where a real Missing Link would solve the problem. It allows the ECU to correct for changes in altitude that voltage clamps cannot solve.
read up on www.synapseengineering.com
Originally Posted by 3ngin33r1,Mar 21 2005, 06:34 AM
what VAFC version?
Also after driving back at lower altitudes(5,280 ft) for a while the check engine light turns off.
This is what my resident honda expert said "When you are at 0% closed throttle the ECU will blip the idle air controller for a split second and look for a change on the MAP sensor voltage. SInce your Black box and VAFC are heavily modifying that voltage the ECU probably cant see it. Then it sets a CEL for Map sensor. I have seen this on a few OBD-II cars with VAFCs and high altitude driving. (above 10k feet)
What are your VAFC settings?
The only time that the VAFC is modifying voltage is when you have told it to do so. If you're not making any adjustments at 0% then the "blip" should not matter. In addition, if the ECU is "bliping" you should have this problem all of the time, not just at high altitudes.
Have you had the VAFC tuned?
I'd say pull the VAFC.
