check engine light, stalling, bucking
Old May 17, 2007 | 09:20 AM
Radfords2k's Avatar
that is the one i need?? thanks
Old May 17, 2007 | 09:27 AM
djpeak10's Avatar
I am pretty sure the only difference between map sensors are that zip tie thingy.
I am unaware of 1 bar 3 bar.
Please let me know if this fixes your problem. Clear your code out when you put in the new map.
Old May 17, 2007 | 09:39 AM
Radfords2k's Avatar
2 things, how do i clear the code out? and is the sensor you just linked me to aftermarket? because i called a honda dealer and they said they have an upgraded one, but the part numbers didn't match...but the info i found earlier did match, so i'm just makin sure we get the right thing.
Old May 17, 2007 | 10:06 AM
djpeak10's Avatar
Yeah the updated one is with that zip tie, If you want to save some time just go to honda and get the one that they have.
You can pull the fuse from under the dash that says "back up" for a couple of minutes or just disconect the negative battery terminal for 30 seconds.
Old May 17, 2007 | 10:40 AM
Radfords2k's Avatar
ok thanks a lot for the help, i just called the shop where my car is, they told me it was the map sensor and they replaced it and so far the car is running fine. i'm guessing they put the newest one in,like the one you just showed me. they are going to call me after they test drive it again and i can go get it! hopefully it will all work good from now on, and i'll let you know the part number of the one they installed as well.
Old May 18, 2007 | 08:35 AM
Radfords2k's Avatar
inline installed a new map sensor, it is the factory one that is now used. it wasn't the old one like i had. everything seems to be working great so far. if you want the part number let me know.
Muggus
Sep 30, 2017 02:41 PM
Planets
May 11, 2008 09:52 PM
QUICK_AG
Jul 31, 2007 04:35 PM
Radfords2k
May 17, 2007 09:59 AM
L200
Apr 26, 2007 10:30 PM
