Check my turbo list please!
Full-Race GT3 Kit:
AEM EMS 1052U(used):
Ironman Clutch Kit:
Competition Flywheel:
Krank Vents:
GM Boost Control Stolenoid:
AEM Map Sensor:
Greddy Turbo Timer:
Ultimate Racing Oil Relocator:
Defi 60mm boost gauge:
Defi 60mm oil pressure gauge:
Defi Version II control unit:
Defi Oil pressure sensor:
Defi Boost pressure sensor:
Cusco catch can
Greddy Oil cooler
Greddy Profec B spc2 boost ctl:
1000cc low impedance injectors:
Injector clips
AEM peak and hold injector driver:
AEM FPR
Battery and relocation
Heatshielding (options??)
Thanks!
Ironman Clutch Kit:
Krank Vents:
AEM Map Sensor:
Greddy Turbo Timer:
Cusco catch can
Greddy Oil cooler
Injector clips
AEM FPR
Thanks!
^^ If you have a choice, do the GReddy Profec B Spec2 BC over the GM Solenoid...
Also - any particular reason you want to spend the cash for an AEM Peak & Hold Injector Driver instead of just using a Honda Resistor Box?
Get a resistor box.
Originally Posted by fperra,Mar 10 2007, 06:49 AM
I've done both the resistor box and the Peak & Hold driver, and the P & H driver is the way to go. Car idles much better. Resistor box is a band aid fix for P&H injectors. However, if you want to go with the resister box let me know. I've got two of them for sale.
Originally Posted by ChefJ,Mar 9 2007, 01:10 PM
3mm headgasket. With the kind of hp you are looking at you have to lower the compression. Its either that or pistons and rods.
Prob right at 400whp
