Chefs go at 1/4 miles
Ok guys so I went to atco raceway in jersey Friday.. I did 5 runs .. I never got a perfect launch .. Run 4 video is a 1500 rpm launch and run 5 is a 4000 launch .. Run 5 was my best of night . Here's the ticket .. I'm 84 left lane . [attachment=86679::] I could be in the 11 s if I keep my 60 ft time down .. Next time I will launch at 5 k and commit more .. It's very sticky and takes a while to get used to the feeling on the rear end .. Thank god I have the ford diff and 1000 hp axels .. https://youtu.be/EsRd7gHcXXErun 4 https://youtu.be/fa5bV815AnYrun5
[attachment=86951::]
Kraftwerks supercharger
420 hp 280 tq
Dunlop direzzas z2
Cnc ford 8.8 diff
1000 hp dss axels
33 spline hubs
Extended studs
Next time I will .. I need a few more runs to see where I have to launch at .. I can def get into 11
420 hp 280 tq
Dunlop direzzas z2
Cnc ford 8.8 diff
1000 hp dss axels
33 spline hubs
Extended studs
420 hp and 300 tq? doesn't sound right.
also be careful even with the ford rear end. Key is being smooth. Even with the diff and axles you move the weakest link to the driveshaft and than transmission.
Originally Posted by s.hasan546
420 hp and 300 tq? doesn't sound right. also be careful even with the ford rear end. Key is being smooth. Even with the diff and axles you move the weakest link to the driveshaft and than transmission.
Definitely not something they're made for (and for that I'm grateful, because they're fantastic at what they ARE made for), but keep in mind this is a centrifugal blower and torque peak is biased very late in the rev range. A 420hp turbo s2000 would have a much better trap speed, as there is more power under the curve.
