Chefs go at 1/4 miles
Old Oct 26, 2015 | 12:42 PM
s2000Junky's Avatar
300trq isnt correct for 420whp on a centrifugal blower. 280trq tops. The only way 300trq would happen at this hp is if its a stroker and or if the belt is slipping at peak hp and shaving the peak hp number off the chart, normally providing 450+ whp without belt slip.
Ap2 stock rev limit and short ap2 trans is not an ideal set up for maximizing 1/4 times. Ap1 transmission and revving to 9k rpm with a 3.90 will improve the trap speed by several miles per hour letting the car rev out and not needing to shift into 5th. Running a 3.60 rear end and boosting the car up to 450whp+ should get it into the mid 120's.
Old Oct 26, 2015 | 12:47 PM
chefs2000's Avatar
Originally Posted by s2000Junky
300trq isnt correct for 420whp on a centrifugal blower. 280trq tops. The only way 300trq would happen at this hp is if its a stroker and or if the belt is slipping at peak hp and shaving the peak hp number off the chart, normally providing 450+ whp without belt slip. Ap2 stock rev limit and short ap2 trans is not an ideal set up for maximizing 1/4 times. Ap1 transmission and revving to 9k rpm with a 3.90 will improve the trap speed by several miles per hour letting the car rev out and not needing to shift into 5th. Running a 3.60 rear end and boosting the car up to 450whp+ should get it into the mid 120's.
your correct it's 280 not 300 tq.. I just checked my old thread ..
Old Oct 29, 2015 | 11:27 AM
Forcednduckshn's Avatar
Originally Posted by chefs2000
Ok guys so I went to atco raceway in jersey Friday.. I did 5 runs .. I never got a perfect launch .. Run 4 video is a 1500 rpm launch and run 5 is a 4000 launch .. Run 5 was my best of night . Here's the ticket .. I'm 84 left lane . [attachment=86679::] I could be in the 11 s if I keep my 60 ft time down .. Next time I will launch at 5 k and commit more .. It's very sticky and takes a while to get used to the feeling on the rear end .. Thank god I have the ford diff and 1000 hp axels .. https://youtu.be/EsRd7gHcXXErun 4 https://youtu.be/fa5bV815AnYrun 5 [attachment=86680::]
[attachment=86727::]
I have always loved drag racing. Cool car. Launch higher, even at 4k the launch was a bit bogged. Good luck on the 11 sec goal!
Old Oct 29, 2015 | 07:55 PM
MARK AUS S2K's Avatar
Jesus mate that this is fast!
Really enjoyed watching both videos!
Old Oct 29, 2015 | 11:52 PM
chefs2000's Avatar
Thanks fellas ! I'll get to 11 easy ..thanks for the tips!
Old Oct 30, 2015 | 05:30 AM
camuman's Avatar
the only negative i will say is need more mph. gonna be tough to squeak out an 11 with a 113 trap. slicks and a 5k+ hard core launch maybe. cut a 1.5-1.6 short. even then. mo powa!
Old Nov 3, 2015 | 06:14 PM
KaNgArOo's Avatar
I need a 8.8 diff. I would love to be in the 11's. With no launching (2.4 sec 60ft.) i managed a 12.8 sec run only.
Old Nov 4, 2015 | 05:46 AM
chefs2000's Avatar
engine mods? Geared?
Old Nov 4, 2015 | 05:56 AM
Moddiction's Avatar
Former Sponsor
Nice. Good launch should be definitely very low 12's to 11's. I'd think the MPH would be a good 5 mph higher than that though.
Old Nov 4, 2015 | 06:01 AM
KaNgArOo's Avatar
Stock motor. Inlinepro dual valve springs/titanium retainers. Pfab elt top mount/precision 6165bb turbo. Id1000. Sos dual pump surge tank. Aem fuel rail. Full blown fpr. 3"exhaust. Comptech reinforce diff. Stock transmission. CC stag 4 clutch.
