close
Old Jun 23, 2010 | 11:05 PM
vahe418's Avatar
Default close
close
Old Jun 23, 2010 | 11:55 PM
PsykotiK's Avatar
the 6262 is a bit overkill for those powergoals.. go with the 5857
Old Jun 24, 2010 | 12:10 AM
vahe418's Avatar
well thats just for now i plan on going with more power later on.
Old Jun 24, 2010 | 12:16 AM
03evolution's Avatar
I'd recommend doing a 3mm headgasket too...that is if you're on a stock block. seems to be a VERY popular thing to do to lower compression.
Old Jun 24, 2010 | 12:30 AM
vahe418's Avatar
Really dont wanna take the motor apart if i could even make 400 with this setup on stock motor i would be more than happy but thanks for the input.
Old Jun 24, 2010 | 06:25 AM
siadam's Avatar
Whats "more power" later?
Old Jun 24, 2010 | 07:20 AM
dsddcd's Avatar
You should have no problem laying down 400 on the stock head gasket with this setup but I would definatly look at getting an AP2 exhaust cam to limit the back flow of exhaust into the combustion chamber.
On a cast/Log mani a larger hotside is often very helpfull to lower the back pressure in the system you may want to look at a 5965 or just get it over with and go with a 6265 now. On my car the differnce in spool was not noticable at all but the 62mm has quite a bit more potential. I was able to make 10PSI by 3800RPM.
Oh, and I would NOT recomend the revhard, if you want a bottom mount mani the IP is MUCH nicer and they are proven to hold up much better. I have personally seen several of the Revhards crack and never seen an Inline crack unless it was droped or broken.
Take a look at my build, TurboKev and Revenge we have all done exactly what you are wanting to do. Infact I have my kit for sale now.
https://www.s2ki.com/forums/index.php?showtopic=797977
Good Luck, and we look foward to seeing your progress
Old Jun 24, 2010 | 07:41 AM
vduber's Avatar
^^ I agree if your going to go with a log go with inline pro or a p-fab log. Im surprised you havent been told to get a tubular yet, you can definitely make alot of power with 6262 on a log but tubular are much more efficient and allow you to run less boost while making the same if not more power than on a log. It's all upto you just throwing the idea out there for you but tubulars usually cost close to 1K while a log is a few hundred. Thats my .02
Lankan
Dec 26, 2015 09:29 AM
redx
Jan 5, 2011 11:07 AM
08s2000CRbackinblack
Dec 30, 2009 05:46 PM
dsddcd
Jul 7, 2009 02:48 PM
sbrodacz
Apr 29, 2009 11:46 AM
