Clutch failure? Fork pivot? ACT PP/OEM Disc + PTuning Kit
Old Sep 12, 2019 | 07:50 AM
visionxboy's Avatar
Default Clutch failure? Fork pivot? ACT PP/OEM Disc + PTuning Kit
Was driving on the freeway today and my clutch all of a sudden hits flat. Most awkward situation ever, in a manual car but only left with gas and brake pedal. I pull over, check the pedal. It's on the floor, i prop it back up and its extremely firm. Car will NOT go into gear. Currently awaiting a tow... Question is, what can it be? Am I the only person ever to have their ACT PP/OEM Disc fail? If my disc did fail, can I just toss in another OEM disc and go on my merry way?
Setup:
Clutch: ACT PP + OEM Disc
Mileage: 140k
Miles since boosted: ~30k
Turbo: PTuning Kit, GTX3076R
Power: ~450hp/~300tq on a Dynapack.
Old Sep 12, 2019 | 08:11 AM
gotembro's Avatar
Things to check...
Check the Fluid?
Ensure your not leaking
S2000 is a hydraulic clutch systems. Check your fluid level or adjustment bolt might broke or something. Ensure all the parts are working; before going onto the clutch, trans
Old Sep 12, 2019 | 08:27 AM
soulicious's Avatar
Check your clutch master cylinder. Maybe there is a leak as mentioned. I had to replace mine a few years ago on my ‘05.
Old Sep 12, 2019 | 09:18 AM
flanders's Avatar
Did you use an oem release bearing?
Old Sep 12, 2019 | 10:03 AM
visionxboy's Avatar
Originally Posted by Quad-Damage
Things to check...
Check the Fluid?
Fluids look good. Dropped off the car to my buddies shop. Will update with what went possibly wrong.
Old Sep 12, 2019 | 10:04 AM
visionxboy's Avatar
Yup, BNIB OEM everything except the ACT PP.
Old Sep 12, 2019 | 10:24 AM
stock06's Avatar
Default Model year
Hello,
Just curious what year your car is and region or state you are in?
Thank you.
Old Sep 12, 2019 | 10:59 AM
visionxboy's Avatar
Originally Posted by stock06
Hello,
Thank you.
2006. Still has CDV. I'm in Southern California.
Old Sep 12, 2019 | 11:20 AM
EOE's Avatar
EOE
Can you get into any gear? Could your clutch-fork have possibly slipped off? If you take the rubber boot off on the transmission that covers the slave cylinder hole... check there.
Old Sep 12, 2019 | 11:38 AM
visionxboy's Avatar
Originally Posted by EOE
Can you get into any gear? Could your clutch-fork have possibly slipped off? If you take the rubber boot off on the transmission that covers the slave cylinder whole... check there.
Car will NOT go into gear while its on. While it is on, the clutch pedal feels INCREDIBLY STIFF. But will go into gear when its off.
