Cold AIT's and boost
Originally Posted by Hondata
PID control is difficult for boost control is some ways. To start with you need the wastegate and control solenoid plumbed correctly so that the natural boost curve is flat to begin with. Next you need a starting duty cycle to boost table and correction table. Then you need to tune a correction table and then go through the PID setup process, where you change P values to achieve a certain frequency, and then turn the I and D components. It turned into a lot of fiddling around, far more so that the straight duty lookup we currently use, and we felt many people would not achieve good boost control. Perhaps it will be an option in the future.
As a bridge, I've also asked for a boost temp comp table to be added that would be way easier to setup and maintain. Here's that response:
I do not believe there is room in the ECU for another table.
Yeah I went out the other night and retuned right up the load lines to 15psi, so the fueling is fine now.
When it started happening I would see WOT afr's around 0.7 leaner which would gradually come back down to my usual 11.8:1 after 25mins..At first I thought the problem was fuel was sticking to the cold inlet ports, so I messed around with the coolant temp comps and AIT comps...then I did a load of data logs on my way to work and saw the boost pinning, and then coming back to normal 10/10.5psi once the engine bay had warmed up and the intake temps had risen. so then it was pretty obvious it was over-boosting.
josserman
Apr 14, 2012 07:03 PM
