Cold starts in the morning issue...
Before posting, I did a search but couldn't find a solid answer. Here's what happens. When starting the car I crank longer than usual (clutch in & holding start) takes about a full 1-2 seconds to crank and start engine. Also it seems like the car takes a little longer to warm up to 3 bars (start car wait 30 secs and drive shifting at low rpms) I talked to Honda they think it might be a fuel management issue but can't confirm this without full inspection. I read somewhere while searching that the ECU learns as the weather changes? Anyone else experiencing this? Thanks in advance.
Originally Posted by xviper' date='Feb 7 2005, 01:51 PM
This is pretty well known and is quite common. 1 to 2 seconds to crank and fire? Nothing wrong with this.
All kinds of environmental parameters will change the way an S2000 starts and runs - ambient air temp, barametric pressure, relative humidity, smog content, etc.
Many owners will also report that when there is a significant transition from fall to winter, their cars will start up, run for a couple of seconds and die. Upon the second start, all is normal. In time, without driver input, the ECU will learn over 4 to 5 five such episodes and then be perfectly fine. Only if it never learns, do you have a problem.
Mines the same way, starting and warming up. I had a fuel issue before I believe. Xviper correct me if Im wrong becasue Im guessing my situation.
Youll know if you have a fuel issue when you start to drive the car when its cold and when it revs up to about 3 or 4000, it hesitates a bit. Kind of like your still hitting the gas, but the engine dosent wat to go. I thought it was normal until I got it dynoed and turned up the FPR. Now that hesitaion is gone.
My guess was that the ecu was doing something becasue it was not getting enough fuel when cold.
I'm glad that tuning and turning up the fuel pressure can eliminate this hesitation for you. I'm not all that concerned about it as it is so minor a thing. I'm sure if you were to get rid of the MAP clamp by using a stand alone aftermarket ECU, this hesitation can be gotten rid of, too.
You are right, it only does it once after the cold start. The FPR tuning did completely eliminate it though.
