Combustion Chamber Volume
Old Feb 13, 2015 | 11:10 AM
Sideways's Avatar
Default Combustion Chamber Volume
I am preparing a new head and measured the combustion chambers at 54cc. My last head has 55.2cc chambers and gave me very low compression.
I am curious how small have others gone with the combustion chamber. I want to surface the head and that will make the chamber smaller. Anyone running 53cc chambers?
Old Feb 13, 2015 | 03:00 PM
wadzii's Avatar
Banned
I've measured a few, they all seem to come in right at 53-54cc
you have to watch piston-head clearance once you start milling the head a ton. I've run mine milled upwards of 0.030". Never measured the chambers at that point.
Old Feb 14, 2015 | 06:21 AM
jaundice's Avatar
Won't that increase your CR a little as well? What CR are you after sideways?
Old Feb 14, 2015 | 12:44 PM
Sideways's Avatar
I have 9:1 pistons with the large chamber volumes it is probably around 8.5:1. I've done compression checks and it runs 155 per cylinder.
9.5 would be nice.
Old Feb 14, 2015 | 03:42 PM
Brutus's Avatar
9.5 would be nice.
...and your still pulling down like 550 rwhp?
nice
Old Feb 14, 2015 | 03:50 PM
wadzii's Avatar
Banned
If I remember my calculations right decking the head 0.015 will get you almost a point
Old Feb 19, 2015 | 11:41 AM
Sideways's Avatar
A little heads up,
0.010 inches milled removes 1.5cc chamber volume.
This is theoretical using the bore size and also confirmed with measuring the chamber.
Old Feb 19, 2015 | 11:52 AM
wadzii's Avatar
Banned
The s2000 chamber is only 86mm not 87mm
Old Feb 20, 2015 | 07:55 AM
Sideways's Avatar
Yes, I rounded from 1.48cc
s2000sccaracer
Feb 15, 2017 10:11 AM
beaudin223
Nov 4, 2016 01:18 PM
fatjoe10
Dec 3, 2009 07:25 AM
Sideways
Jan 3, 2006 11:15 PM
GDM S2K
Oct 17, 2005 06:09 AM
