Cometic or Inline Pro Headgasket
Old Jan 31, 2007 | 05:41 AM
YuriArts's Avatar
Originally Posted by AROD,Jan 31 2007, 06:18 AM
too much?? What do you mean by too much??
once a person makes 400 hp, they get bored of it, he'll want more, if hes gonna go thru the trouble of gettin a gasket might as well go 3mm so you can up the boost when you get bored with 400. I made 400 hp on very easily with the 3mm, got bored of it, and up went the booossttt. Even if he wants to stay at 400, 3mm will be fine.
My opinion is that lowering the compression to 9:1 ish you are losing engine caracteristics. It's a high compression, high revving engine.
If you only lower compression with the 2mm HG, you will be near stock and still be safe on 400whp.
Ofcourse, if you want 500whp on normal gas you will need the 3mm HG.
Or you could go race gas.
Old Jan 31, 2007 | 05:49 AM
AROD's Avatar
[QUOTE=YuriArts,Jan 31 2007, 09:41 AM] My opinion is that lowering the compression to 9:1 ish you are losing engine
Old Jan 31, 2007 | 06:57 AM
Spoolin's Avatar
Originally Posted by AROD,Jan 31 2007, 09:49 AM
with a 2mm your compression will NOT be near stock lol, and with my 3mm i still rev to 9k and make power, how is that losing the engines characteristics, if anything my torque and hp make my engines characteristics much much better. All i'm saying is, if your gonna use a gasket to lower compression, might as well go with a 3mm, this way, you can easily handle the 400hp and turn up the boost if needed.
I think he is talking about off boost driving at lower rpms. At 11:1 compression you will have a little more low end torque off boost and the driveability is a little better.
Old Jan 31, 2007 | 07:18 AM
ideugene's Avatar
I have a Cometic gasket and the fitment was not exactly perfect. It has some high spots and what not but if Inlinepro offered a 89mm bore 1mm gasket I would have gotten that.
Old Jan 31, 2007 | 07:25 AM
AROD's Avatar
what do you mean by drivability?? alil confused on that, my car drives perfectly fine on low rpms. I have driven my car n/a with a 3mm headgasket since we installed the gasket first and made sure nothing was wrong, yes i felt a lack in power, big amount, so i do not think a 2mm would feel "that much better" or anything close to "stock" I understand what you mean about comparing an 11:1 compression motor to a motor with a gasket to lower compression, but he is talking about 2mm to 3mm
Old Jan 31, 2007 | 07:28 AM
CourageOO7's Avatar
Originally Posted by YuriArts,Jan 31 2007, 08:27 AM
What's wrong with the cometic 2mm HG?
I know it's only 2mm and the inlinePro's 3mm but are there proven weaknesses on the cometic?
I've also read that the Cometic gaskets tend to leak whereas the Inline gasket is a perfect fit. I have never heard of one leaking. HOWEVER, I think I read that Inline CALLED Cometic and brought the issue to their attention and that Cometic revised their product because of this.
If this is the case I'd buy an Inline based entirely on their commitment to bettering the platform.
Old Jan 31, 2007 | 11:08 AM
NFRTurboTerror's Avatar
[QUOTE=AROD,Jan 31 2007, 08:18 AM] too much?? What do you mean by too much??
Old Jan 31, 2007 | 11:59 AM
AusS2000's Avatar
Can someone confirm that current Cometic 2mm gaskets are revised and don't exhibit the problems of the earlier ones?
A couple of us here are interested and would like to know.
Old Jan 31, 2007 | 01:27 PM
S2KB00ST's Avatar
By dropping the compression an extra point u are not even going to feel the extra sluggishness during off boost driving in the real world you 'think' you would get. Together with advantage of having the extra room for error in tuning (gas, environment deviations etc..) with the 3mm, and the potential to up the boost further, I really can't see why anyone would want to go 2mm!
Old Feb 1, 2007 | 10:21 AM
j_c_a's Avatar
Originally Posted by C45P312,Jan 31 2007, 08:02 AM
And supposively you can run the inlinepro 3mm hg with 14-17psi daily driven and still be safe
Actually you can safely run quite a bit more boost than that
