compatibility with comptech supercharger
Old Apr 12, 2006 | 10:51 PM
Titounais's Avatar
Thumbs up compatibility with comptech supercharger
I want to know if I can put a comptech supercharger that comes from a 2.2 engine (2004 +) for my 2003 s2k with the 2.0 engine. Someone have any experience of it? ANd by the way, if I pay 5000$ Canadian dollar for it (used) with all the stuff plus the aftercooler, is that a good price?
Old Apr 13, 2006 | 12:51 AM
AusS2000's Avatar
Yes you can. The only major difference is that the 04-up pulley is smaller so you will have your 6psi (or whatever it's supposed to be) at 8000 and will have a bit more at 9000. This is the sort of upgrade most Comptech owners do eventually anyway.
And regardless, you want to get a simple tune done to make sure you're not running lean. 10 minutes on the dyno and a twist of the FPR screw and you're done. Just drive to the dyno without thrashing it.
Old Apr 13, 2006 | 04:44 AM
j_c_a's Avatar
Just what Aus said. Also, just FYI, you'll need to drill and tap a small hole for the FPR bracket on an AP1 as the mounting is slightly different. No big deal at all.
Old Apr 13, 2006 | 07:59 AM
s0rted's Avatar
As Aus said, it's the equivalent of upgrading to a 7psi pulley on the standard kit. Also I think the horn position's changed, so you might have to relocate it - no biggie. $5000 Canadian sounds like a fair price considering they're upwards of $5000 US new. good luck
Old Apr 13, 2006 | 08:17 AM
gomarlins3's Avatar
Just be sure that everything is included with a used kit.
Old Apr 13, 2006 | 11:11 AM
Titounais's Avatar
So you guys are telling me that it is preferable to get the supercharger for the 2.2 engine to put on the 2.0 engine and it is like an upgrade because the pulley is smaller and I can get more psi? Right? BTW what is FYI ? AP1? FPR bracket? Sorry it's my first experience about supercharger.
Thank a lot
Old Apr 13, 2006 | 01:43 PM
silentdancer's Avatar
Thank a lot
for your information, ap1 = chassis code for 2000-2003 s2000's, fuel pressure regulator? i think
Old Apr 13, 2006 | 03:54 PM
s0rted's Avatar
Yupp, that's pretty much it...
myflys2k
Southern Ontario For Sale
25
May 25, 2010 06:51 AM
Sondra S2K
Apr 17, 2008 10:24 PM
home13oy75
Sep 24, 2004 06:08 AM
