Competition Clutch
Old Feb 22, 2007 | 08:54 AM
S_NeWb's Avatar
Default Competition Clutch
does CC clutch whine? I have Competition Clutch w/light weight flywheel. I notice its whining more than b4. It whine when i let go off the gas? I cant tell if tis the clutch or something else is whining.
Old Feb 22, 2007 | 09:58 AM
Spec_Ops2087's Avatar
Are you sure it is a whine or is it more of a buzz? Light weight flywheels are known to cause clutch buzz which is normal.
Old Feb 22, 2007 | 10:34 AM
S_NeWb's Avatar
hmm maybe buzz. It happens when i let go of the gas. its louder than my exhaust's drone
Old Feb 22, 2007 | 11:00 AM
More lilkely then not, thats what we call clutch buzz. Its normal to lightweight flywheels as well as certain kinds of clutches. For the record, my comp. clutch buzzes on deaccel and even stock 00-01 s2ks OEM clutches buzzed.
Perfectly normal I'd say.
Old Feb 22, 2007 | 11:09 AM
gomarlins3's Avatar
Kane sells them, he may be able to shead some more light on the subject.
Old Feb 22, 2007 | 12:06 PM
slimjim8201's Avatar
I have a stage 3 Competition Clutch and there is a noticeable buzz on decceleration at around 2800-3200 RPM. Not super loud but a buzz nonetheless. I have noticed a slight whine at lower speeds that was not there prior to my turbo install. It is road speed dependent so I'm sure that is also the clutch.
This clutch is still making me look like a total idiot starting in first on slight inclines.
Old Feb 22, 2007 | 12:15 PM
S_NeWb's Avatar
I also have a stage 3. Mine is super loud(i guess depend on your ears). yeah i started to notice it now since my turbo is off. Dunno why now but not b4 when i was turbo charged. B4 my exhaust wasnt as loud since i was turbo charged, but now i am NA the exhaust is louder, drone worst, and now the buzz. It buzzzzzzZZZZZZ. The clutch work great but its annoying
Old Feb 22, 2007 | 12:18 PM
Erick S's Avatar
Engagement is rather quick and can be tricky
Old Feb 22, 2007 | 12:23 PM
CaptKirk's Avatar
I recently got the iron man clutch w/lighter flywheel installed and I feel the same way... I feel like a freakin n00b whenever I'm driving The thing grips so hard and fast, the clutch pedal is softer and the rpms drop so much faster cuz of the FW... It's gonna take some practice for this
Old Feb 22, 2007 | 12:34 PM
After driving the clutch a bit I've pretty much figured out how to make a pretty smooth engagement.
Rev her up to 3-4k rpms and just slip the clutch. I've noticed if you only rev it up to 3k or less it'll buck like crazy and make for a very rough engagement. Remember puck style clutches don't make that horrible smell if you slip them at a high rpm (due to the friction material) so slip it all you want.
With that being said, its not to bad from a dead stop anymore
