Comptech Ap1 boost question
Old Apr 12, 2012 | 06:44 AM
jsenclosure's Avatar
Default Comptech Ap1 boost question
AP1 with stock comptech kit
Where are you guys starting to gain boost? I'm not sure if i have an issue with my gauge or possibly something else but i'm not seeing any boost until i'm probably in the 7-8k range and even then the most i'm seeing is 4psi (1 time), but most frequently no more than 2psi is the highest i'm seeing on my gauge. Using an aem digital gauge attached to the intake manifold vacuum line btw.
Suggestions?
Old Apr 12, 2012 | 08:27 AM
05APdeuce's Avatar
I do not hit full boost until after 7k but I get atleast 7-8 psi by 5500 rpm. Have you checked to see if your belt is slipping?
Old Apr 12, 2012 | 08:33 AM
yeah i have, i don't believe my belt is slipping at all. I'll check it again tonight, if anything the tenion on my belt would be too tight.
what pulley are you running btw?
Old Apr 12, 2012 | 09:15 AM
s2konroids's Avatar
If your running stock 5.5psi
Its linear, so at 6k rpm you should be seeing about 2psi, 7 3psi and 8 4psi and just before the redline 5.5psi
Old Apr 12, 2012 | 09:32 AM
i'm going to change my belt and check again for vacuum leaks and hope that takes care of it.
Old Apr 12, 2012 | 09:37 AM
passmans2kny's Avatar
does the car feel like its pulling hard up top? does it feel slower than b4 this was happening?
Old Apr 12, 2012 | 09:41 AM
doesn't fell any slower, feels hard up top but i can't tell to what degree
Old Apr 12, 2012 | 09:47 AM
might be ur boost gauge then
Old Apr 12, 2012 | 09:52 AM
I kind of doubt that, it's a brand new gauge and i've never had a problem with an aem gauge before
Old Apr 12, 2012 | 11:22 AM
05APdeuce's Avatar
3"
