comptech blower pulley
Old Feb 18, 2011 | 02:50 PM
erikvanden's Avatar
Default comptech blower pulley
Hello, I have a comptech SC with a VAFC. I am only making about 4-5lbs with the AC and larger heat exchanger. I was looking to get 4.2in pulley for the blower before I have a shop adjust the car with the VAFC to get an extra lb or so. I haven't been able to find a used pulley or a new one. It is easier to find the pulleys new on mustangs sites as they often have novi 1000 blowers but all I can find so far is the 4.25. http://www.horsepowerfreaks.com/performanc...charger_Pulleys
Does anyone have an idea where I can get the 4.2in pulley (stock AP2 size) for the novi 1000?
Old Feb 18, 2011 | 03:27 PM
gettin it's Avatar
Are the comptech and vortech pulleys the same?
Old Feb 18, 2011 | 03:56 PM
erikvanden's Avatar
almost positive no. there are different pulleys for different novi blowers so i would assume pulleys from different manufactures wouldn't be compatible.
Old Feb 18, 2011 | 04:43 PM
ScienceofSpeed's Avatar
Former Sponsor
The Vortech does not use the same offset as the Comptech kit. We have the solution for you:
http://scienceofspeed.com/products/engine_...000_SC_pulleys/
The standard kit at sea level produces 6 psi. I assume you are not at sea level, or have something different about the kit (such as a front mount intercooler) to have this pressure drop. If not, that should be investigated further.
-- Chris
Old Feb 18, 2011 | 05:24 PM
erikvanden's Avatar
-- Chris
correct. But you don't have a 4.2in listed for sale. I actually just placed an order for a sport clutch a few hours ago from you guys. I would have bought the 4.2 but biggest you have is a 3.6. The next best option I have seen is the 4.25 (which is available almost anywhere including Paxton's site) which shouldn't be much different than the 4.2. I am still on stock injectors and if I go smaller than the 4.2 i might not be able to keep the air flows in line. I was just going to pick one up for a small power boost at a low cost (not having to do a better piggyback/stand alone or injectors)
Old Feb 18, 2011 | 06:49 PM
s2000Junky's Avatar
I believe the 4.25 is the pulley size used on the stock Comptech ap2 kit, not 4.2. SOS uses a 4.2". I had good success running the 4" without engine management or meth injection. SOS seems to have discontinued production of their 4" &3.8" pulleys for some reason.
Old Feb 19, 2011 | 09:10 AM
erikvanden's Avatar
It says on the SOS site that the stock AP2 is a 4.2. That could be incorrect though or that 4.25 might actually be a 4.2 or there may be some reason it is listed as that.
Anyway, my FPR is backed out almost all the way and a 4.0in might be pushing it as that would probably be around a 2-3PSI boost increase. Right now I am just trying to find a 4.25 pulley that is reasonably priced.
Old Feb 19, 2011 | 11:53 AM
s2konroids's Avatar
I can measure my stock ap2 pulley if you want? - however some folk measure them from different points.
I have CT AP2 one on my AP1.
Old Feb 19, 2011 | 03:46 PM
erikvanden's Avatar
Thats ok it may be very difficult to determine the size from actually measuring the thing. At least when going for .05 of an in.
Old Feb 19, 2011 | 05:48 PM
s2000Junky's Avatar
I assume you mean screwed down?
4" got me 8psi on the nose at 9k. I maxed out my fpr and used my vafc to lean out the fuel pre vtec. If you have a larger TB, or big single 70mm exhaust/header then you may not have enough fuel for the 4". With my breathing mods at the time I had just enough to run reliably.
Then I found meth injection and the rest is history....
