comptech blower pulley
Old Mar 2, 2011 | 07:20 AM
erikvanden's Avatar
Originally Posted by s2000Junky
I assume you mean screwed down?
4" got me 8psi on the nose at 9k. I maxed out my fpr and used my vafc to lean out the fuel pre vtec. If you have a larger TB, or big single 70mm exhaust/header then you may not have enough fuel for the 4". With my breathing mods at the time I had just enough to run reliably.
Then I found meth injection and the rest is history....
yes screwed down. I think I will go with the 4.25 just to be safe. I am just looking for a bit more power. I do have an aftermarket exhaust and 70MM test pipe. The cat back isn't that big though. I can't imagine the new pulley would effect the AFR much if it isn't much smaller.
Old Mar 2, 2011 | 12:58 PM
s2000Junky's Avatar
[/quote]
Expect your afr to go from a starting hypothetical of 11.5 to 13afr with each 1psi of boost. So about 1.5 points is what I have noticed in general. Your next size pulley will give you 1psi/15whp
You will need to add aprox 1-2 full turns further down on your fpr to give you some idea
johninator
Jul 23, 2006 03:47 PM
folex187
Jan 4, 2006 08:26 PM
hydeaway
Mar 8, 2005 02:50 PM
D-S2K
Dec 16, 2004 03:39 PM
