comptech diverter valve
Old Mar 4, 2010 | 12:30 PM
lvd1102's Avatar
Default comptech diverter valve
I currently have a comptech s/c i just recently installed the UR FMIC with the HKS SSQV blow-off valve. I was just wondering instead of finding something to plug the hole where the dirverter valve is, can i just leave the vavle in without the vaccuum line hooked up. Just wondering if the valve is closed when there is no vaccum pressure? or is it always open?
Old Mar 4, 2010 | 05:57 PM
goldenfri's Avatar
That's a good question. I am just finishing up my install and I was wondering what to do about that hole.
Old Mar 4, 2010 | 07:31 PM
jaundice's Avatar
You can leave the valve in the hole. That is just an intake side anyway, and would whistle and pull hot air in if left open. Take your valve off and try to suck air into it. If you can suck air, try the other way. Put it back in in the direction that air cannot be sucked in.
Or simply go to home depot and buy a plastic plug that fits into the hole.
Old Mar 5, 2010 | 06:48 AM
\\s2kris//'s Avatar
would this work?
http://www.atpturbo.com/mm5/merchant.mvc?S...tegory_Code=BOV
Old Mar 5, 2010 | 07:16 AM
jaundice's Avatar
sure, but just go to home depot and get a plastic one for 2 bucks.
Old Mar 5, 2010 | 07:31 AM
goldenfri's Avatar
Thanks
Old Mar 5, 2010 | 12:17 PM
lvd1102's Avatar
where in homedepo would this be? plumbing? hardware?
Old Mar 5, 2010 | 06:36 PM
goldenfri's Avatar
I went to the plumbing section and found a PVC end piece for $0.16 that I was able to squish in there just fine. Should do the job.
markforrester99
Jul 11, 2017 12:46 AM
ScienceofSpeed
Jan 14, 2010 09:19 PM
StockSH
Oct 12, 2004 01:34 PM
AusS2000
Jan 29, 2004 04:57 PM
Honda-S2000VTec
Dec 4, 2003 05:25 PM
