Comptech intake elbow plug
Old Jan 29, 2013 | 12:20 AM
BB02s2k's Avatar
Default Comptech intake elbow plug
For those of you that have an aftermarket BOV that's not a Turbosmart Kompact, what do you use to plug up the bypass valve inlet on the intake elbow? I've been using a cheap plastic plug with duct tape.. Looking for a more permanent solution!
Old Jan 29, 2013 | 09:28 AM
Torque Obsessed's Avatar
How big is the hole? On the SOS kit, I discovered that I could jam something like a plastic cap from a 2-liter Coke bottle into the hole. Then I drilled holes through the side of the cap and the side of the elbow, and ran some zip-ties through to lock it securely in place. Didn't want the blower to ingest it.
Old Jan 29, 2013 | 09:41 AM
s2000Junky's Avatar
There is a perfect 'clean' solution I found at the hardware store. Its a 1" 'expandable' plug just the same as you would use for a temporary freeze plug on an engine block. It’s like a rubber grommet with a steal top and nut on top. You put the plug in and tighten up the nut and it expands inside the hole for a tight fit. I put mine in over a year ago and it’s never come out. Its totally reversable as well. Easy $2 Solution.
I found a pic of exactly what I used here /
http://www.google.com/imgres?q=tempo...6&tx=132&ty=86
Old Jan 29, 2013 | 09:56 AM
jordannn93's Avatar
I got a rubber cap that goes on the bottom of a chair leg I think from Home Depot and it worked good
Old Jan 29, 2013 | 09:57 AM
jordannn93's Avatar
http://images.orgill.com/200x200/2192458.jpg
Old Jan 29, 2013 | 01:58 PM
BB02s2k's Avatar
Thanks for your input guys! I'll definitely look into that freeze plug since it's readily available!
tritium_pie
Feb 13, 2016 09:57 AM
dsddcd
Feb 24, 2014 07:53 AM
sutats
Sep 9, 2010 09:54 PM
JiNSOKU
Mar 17, 2009 05:09 PM
ayS
Jan 21, 2006 03:40 PM
