comptech quetsion?
Originally Posted by 05berlinas2k,Dec 22 2005, 02:44 PM
so what putting a supercharger on a 04-05 isnt worth it? theres no way to acheive full booost? Someone hasnt come up with some great idea yet
^ Exactly! You asked about a kit for an AP1. These won't give you max boost. Comptech has altered the kit for the AP2 to compensate for the lower redline. It involves a smaller pulley and if memory serves me correctly, it might even incorporate an additional injector and other minor tweaks.
Originally Posted by r_duff,Dec 22 2005, 03:20 PM
hey can the smaller ap2 pulley be fitted to the ap1 kit to give a bit more boost? if so, will it require a stand-alone fuel management system?
It also depends on what boost pressure you are currently registering. You shouldn't need a stand alone if you keep the max boost to around 7 psi. Once you get to 8 or more, you are getting into tricky territory with the stock setup.
Originally Posted by 05berlinas2k,Dec 22 2005, 10:44 AM
will the 00-03 kit fit 04-05 s2000's?
X is right about the pulley.
Don't forget that the FPR is set different from Comptech and will need a street tune.
Also that the Carb EO will not match the Model year of your car and will fail smog if it so applies to you.
You can order the AP2 kit pulley from comptech and adjust the FPR with a few clicks.
Originally Posted by r_duff,Dec 22 2005, 07:41 PM
ic ic, thanks for the info... and yes im ac'ed. My autometer guages shows 5.5 peak boost
