Comptech s/c with Emanage Ultimate advice?
Old Jan 11, 2008 | 01:39 PM
s2k_roar's Avatar
Default Comptech s/c with Emanage Ultimate advice?
I'm about to install a Comptech s/c and an Emanage Ultimate with boomslang harness on my 2002 and I was just wondering if anyone had any extra advice on the Emanage Ultimate part.
I have read most of the previous posts on the Ultimate, and I have a base map to start with, but if anyone has any "new" information for install of the Ultimate since some of the older posts are from '06 and I was unsure if that same information would still be viable now? Not sure if some of the older "bugs" have been worked out with the most recent updates or not?
Any help would be greatly appreciated.
Old Aug 16, 2009 | 11:16 AM
lao_s2k's Avatar
I have AP1 03 CT supercharge and i have the same question about Emanage Ultimate, because i am in Laos and i am order parts from the US so i would like to get all the harness and part in one order by asking expert help from you guys. I try reading so many post on the Emanage (some help and some make me confuse even more)like some dude did it and can't get his S2000 to start and never reply if he manage to get the job done or not?!@#
Please help me answer the following:
1. If i order Emanage Ultimate from Evasive, what hardness should i get and do i still need to order extra harness from boomslang? please find the link below:
https://www.evasivemotorsports.com/Merchant...9920b63bf77666&
2. For installation and tuning, is there any chance for individual can DIY and tune to increase the efficiency of the Comptech supercharge? i.e is it hard ? any chance i can blow or messed up my engine? or you need professional tuner? any step by step instruction for beginner? Laos does not have a good tuner unless i have to drive 8 hours to Bangkok Thailand.
This is what the car comes with when i first import it in 2008 from US:
12,000 miles 2003 S2000 Comptech supercharged NOVI1000 aftercooler, ACT CLUTCH KIT, HEAVY DUTY PRESSURE PLATE, Gear Ratio to 4.57
My Mods: now 15,000 miles
HKS Dual Hi power exhaust/Berk Test pipe/ TEIN dress up string, Defi gauges/ Carbon fiber hood, Carbon Gt mirror, OEM hardtop, ADVAN Model 5 17" rims/ spoon strut bar/ Front lips/ Synchronic Universal BOV
Next Mod and need help:
1.Emanage Ultimate
2.New fuel pump -Walbro or CT ? what is the diff? which is better?
3.Higher Boost pulley (read on form but don't know where to get them?)
4.LSD (Please give recommendation brand with easy maintenance? will it have any effect on the gear ratio set up?is worth to get it? is it hard to install it?
PLEASE HELP !!! thanks
Old Aug 16, 2009 | 06:58 PM
S2SEXY's Avatar
if you are running stock boost and the fpr then all you should do with the emanage is set the map clamp. i can send you my stock base map with map clamp if you'd like.
Old Aug 16, 2009 | 07:00 PM
S2SEXY's Avatar
https://www.s2ki.com/forums/index.ph...f=148&t=408667
start here also make sure your emanage pc software matches your emanage software version.
Old Aug 17, 2009 | 12:34 AM
lao_s2k's Avatar
Thanks S2SEXY for helping me out with the link on emanage ultimate installation and tune however can you or someone tell me If i order Emanage Ultimate from Evasive, what hardness should i get and do i still need to order extra harness from boomslang? please find the link below:
https://www.evasivemotorsports.com/M...920b63bf77666&
Old Aug 17, 2009 | 04:26 AM
S2SEXY's Avatar
http://www.coolcart.net/shop/coolcar...omslangharness
i could not find the harness on evasive so i went directly to the boomslang website
Old Aug 17, 2009 | 07:04 PM
lao_s2k's Avatar
I've check the link you send to me on boomslangharness however nothing shows up on the link as blank, so i am assuming the input on the web is
00-05 Honda S2000
Ultimate (air & water input)
Manual Transmission
correct?
so does this mean i do not need extra harness? i.e this is the only hardness i need and just the e-manage ultimate Unit ? no need for any extra 18-pin, 12-pin, and 14-pin connector harness.
Old Aug 18, 2009 | 04:58 AM
S2SEXY's Avatar
yes thats the right harness air water
nglaser
Aug 7, 2011 07:01 PM
s2k_roar
Jan 11, 2008 07:51 AM
