Comptech S/C Manual
Old Dec 6, 2005 | 04:13 PM
Trip's Avatar
Default Comptech S/C Manual
I read somewhere that the manual has the hoses (assuming step #4) fittings not correctly explained, or incorrect
Although I doubt this, can someone confirm please
http://www.comptechusa.com/store/media/ins...ions/ins072.pdf
Thanks
Old Dec 6, 2005 | 06:18 PM
PWRMKR's Avatar
I might have trimmed the hoses a bit. I followed the diagram.
Old Dec 7, 2005 | 07:59 AM
SIIK2NR's Avatar
The issue is the Air control Solenoid valve that people put the Vac hoses on the wrong way.
It comes with the hoses required.
Old Dec 7, 2005 | 10:09 AM
Trip's Avatar
So the picture on the manual is correct but ppl misplace the hoses.
So this image should be the correct way to route the hoses ?
Thanks
Old Dec 7, 2005 | 10:11 AM
SIIK2NR's Avatar
Yes the diagram is correct.
Old Dec 7, 2005 | 10:12 AM
Trip's Avatar
Cheers
Old Dec 7, 2005 | 10:18 AM
SIIK2NR's Avatar
The issue is that the ACV valve relocating during install can cause confusion on the upper and lower vac hoses.
If you get it wrong you will get a CEL on start up or shortly there after showing 2ndary air injection.
Also make sure you re-connect the toggle plug after re-locating. My partner forgot to do this and I was until I realilzed it was hanging there and not plugged in.
Tim
lvd1102
Mar 5, 2010 06:36 PM
s2kboii
May 23, 2007 12:53 PM
lvietlboyl
Oct 21, 2006 06:39 PM
Squeezer
Jan 29, 2004 09:45 PM
