Comptech S doesnt want to boost :(
Old May 5, 2005 | 04:29 PM
bigfishs's Avatar
I dont think he has an ESM present. Notice the MAP sensor has a vac line attached to it, and then it runs to the secondary air injection system which it shouldnt do if it is a new install.
(I thought you told me via PM that the installation was done years ago). Correct me if I am wrong.
You can also see a bit of the white check valve used to bleed presure from the MAP sensor, the old mechanical way of hiding boost from it.
you can compare with my (also older system)
https://www.s2ki.com/forums/index.php?showtopic=287297
My car is also not running properly and I am having a comptech ESM installed next week.
Hope this helps.
Old May 5, 2005 | 05:10 PM
BroInTheKnow's Avatar
Banned
how many check valves are u running and does it come with the kit?
Old May 5, 2005 | 07:32 PM
djmatix's Avatar
ahhhhhhh bigfishS you are right! My install was done back in 01. Son of a bitch! No wonder everyone is like "there isnt a vacume line that runs from your map sensor" grrrrrrr I might have to expidite the persuasion to purchase the AEM EMS. I cannot stand half ass tuning. All my other cars were razor tuned with a wideband and custom p28 chips......damn b-series spoiling me. My car is a wimp right now, I cant go past ~20% throttle without it bogging. grrrrrrrrrrrrrrrrAAHHHHHH!
what i dont get is why it worked perfectly until 2 days ago. what the gives?
Old May 5, 2005 | 08:27 PM
Banned
when you gonna get it fixed then?
Old May 6, 2005 | 12:40 AM
AusS2000's Avatar
If you want to replace the check valve with a boost limiter I have a Split Second VC1 (the one Vortech use with their SC). It's yours for $60 shipped to your door.
Old May 6, 2005 | 09:42 AM
djmatix's Avatar
hmmm sounds like thats what I would need. How does this compare to the comptech ESM? Also, you are in sydney, how long would shipping take to the states?
Old May 6, 2005 | 10:08 AM
djmatix's Avatar
so its fairly obvious that the check valve is failing because I can half throttle it all the way to redline. but once I stand on it, immediately it bogs. So that would be the map seeing boost and flooding the system out right? Any takers? I have to go test the check valve thats coming off the map sensor. It's kinda dirty and i'm not looking forward to blowing through it.
Old May 6, 2005 | 11:42 AM
bigfishs's Avatar
good luck, hopefully that works out for you. Let me know how it turns out, cause I am going to do the same thing to mine. If you buy the ESM from comptech it comes with installation instructions, but its $149, and add an extra $15 for 2 day shipping (ground is $5 but takes a week). The aussies will only cost you $60 and he could probably walk you through the install.
Old May 6, 2005 | 11:50 AM
Banned
How many check valves do you have on your car?
Old May 6, 2005 | 12:00 PM
djmatix's Avatar
I believe I only have one check valve on my car. I absolutley hate driving it right now. Everything is a threat to me. I had some white RSX-S tail me on the ride to work this morning. I could do nothing!! My roommate is getting a kick out of the crippled S2000. He drives an RSX-S himself. When I get this taken care of, his ass is TOAST!
