Comptech Sc/Ac
Old Apr 7, 2010 | 04:43 AM
kylemonster85's Avatar
Default Comptech Sc/Ac
At the start of winter my supercharged S has been bogging alot and feels like its getting fuel cut. Ive been told that its cuz of the winter gas used in New England. But i also got a cel on saying its my second o2 sensor, but ive been told that when cars are tuned with the emanage blue they throw cel lights. But the way its bogging could it be that the o2 is shot? or is it just the gas?
Old Apr 7, 2010 | 05:33 AM
SRap1's Avatar
secondary 02 sensor just makes sure your catylitic convertor is working, it shouldnt really effect the way the car runs...
it may be getting colder more dense air, which could result in you running lean... when does it bog down? in or out of boost?
what else is done to the car?
Old Apr 7, 2010 | 05:42 AM
out of boost only in light cruising throttle it will do it every once in a while. i just have comptech exhaust and invidia test pipe
Old Apr 7, 2010 | 05:57 AM
legendman's Avatar
I had nightmare bogging/surging issues at idle and low rpms with my supercharger on emanage. Mostly around 2-3k rpms it would run crazy lean for no reason. We couldn't seem to tune it out.
It worked fine with the stock fmu but when I upgraded to emanage I had problems. I went through all the hoops and 'fixes' for surging from resetting the ecu, replacing O2 sensors, replacing MAP, testing TPS, cleaning injectors, replacing injectors....it makes me sick thinking about it.
My only solution was to switch to a standalone, which I realized I should have done in the first place.
Hopefully this isn't what you're going through and it's something simple.
Old Apr 7, 2010 | 06:41 AM
S2SEXY's Avatar
emanage can not,well better put the stock ecu doesnt like when you adjust fuel for partial throttle.what you can try doing is changing the injector size till you get your a/f where you want it.
Old Apr 7, 2010 | 09:30 AM
It was running mint all summer then it started to get cold and wasnt running good. I hope its a simple fix because we have no good tune shops in ct for s2k
superonionman
Aug 19, 2012 02:56 PM
s2konroids
Jul 10, 2010 07:10 AM
THRILLR
Dec 3, 2006 04:50 PM
revhi
Mar 1, 2006 05:17 PM
NMs2000
Aug 8, 2003 09:46 PM
