Comptech SC AFR/Dyno?
So I recently purchased a '04 AP2 Comptech SC car from a member on the board. He had the car dyno'd with an AFR after install and it appears to be in the safe zone from the dyno plot
The only thing done that could affect this since then was the replacement of the OEM mufflers with Magnaflow units. Not a catback but actual mufflers being swapped. There was also a few comments the first time he posted the dyno plot that if the car would've went all the way to fuel cut off there could be some more potential hp left. Really my only concern is that the car isnt running lean so I know I'll have good life expectancy from the motor. If I made 10 less or 5 more whp it wouldnt matter to me either way. So.... would you get it done again just to be sure or is there almost no chance any of that would have changed?
Cool, I'll check to see if there are any local shops that will hook me up. If not maybe I'll give Evans Tuning a call since they did my OBD-I swap in my Prelude.
Thanks
BTW can that be adjusted? i.e. messing with the FPR or is the FPR set specifically by Comptech for the kit?
Thanks
