comptech SC Diverter Valve
Old Oct 26, 2007 | 10:40 AM
ego's Avatar
ego
Default comptech SC Diverter Valve
There is a valve on this that goes from the charge pipe to the intake. It acts like a BOV for SC cars I would think. I need to know what end goes into the intake and what end goes facing the charge pipe. It is the type of valve that comes in VW/AUDI for there BOV on the stock turbo setup. When this was install by inline pro they hooked it up like a BOV so that it dumped into the engine bay insted of back into the intake. Not sure if they know something about this working better or not but I haven't seen one setup like this yet. Any help would be great.
Here is a pic of what is should look like so people know what I am talking about. It's the valve in the intake that hooks to the charge pipe. If that's even what you would call it. I am a turbo guy so this is kinda alittle dif. for me.
Old Oct 26, 2007 | 10:55 AM
ego's Avatar
ego
there is an easy way tell me this. Either the vacume hose to the valve goes facing down or it goes facing the left side of the car (looking at it from the front) it can only go one of there ways
Old Oct 28, 2007 | 09:54 AM
ego's Avatar
ego
NO BODY???? Come on I now that there must be like 100 of these kits on this forum. All you have to do is go look at the valve coming out under the intake tube. I just need to know what way the vacume line in going, facing down or facing the left side of the car ( looking at it from the front). This is an easy one. Any help
Old Oct 28, 2007 | 02:03 PM
ego's Avatar
ego
since no one replied after 54 views I have found my answer to this and will post up so if some one else needs to know here it is.
Old Oct 28, 2007 | 09:09 PM
TRBOKEV's Avatar
Vacuum line faces down.
Old Oct 29, 2007 | 05:52 AM
Ray K.'s Avatar
sorry, I would have responded earlier if I saw this. I have a 1.8T Audi and I run the bosch diverter valve. I also run it boost to the side. People seem to have more problems with those running boost to the bottom. I run 22 psi on mine and I've had it for years with no problems. If you end up at some point having to replace it, go with the stronger one from the TT which ends in part # 710N. The 710A is the one more common on A4's and S4's. They have a softer spring.
Old Oct 29, 2007 | 07:16 AM
ego's Avatar
ego
thanks for the responses guys. I looked high and low for this and not one answer. I found the answer on google and that pic. I think if it ever did go bad from what I have been reading it is a good idea to go with a forged one that they sell. No biggy cause I ordered a front mount for this kit and it comes with a BOV insted of this diverter valve.
doorman
Mar 7, 2004 11:43 PM
SLiCKYV
Feb 16, 2004 08:09 PM
AusS2000
Feb 9, 2004 11:46 AM
jayn
Feb 5, 2004 10:39 AM
AusS2000
Jan 29, 2004 04:57 PM
