BOV for comptech supercharger?
Old Feb 23, 2004 | 08:13 PM
doorman's Avatar
Default BOV for comptech supercharger?
Anyone recommend a BOV for the Comptech supercharger? Don't know if one is needed. Also, what oil are you running with the SC?
Thanks for the info.
Old Feb 26, 2004 | 04:08 PM
Jip69's Avatar
aftercooled or nonaftercooled??
JP
Old Feb 26, 2004 | 04:31 PM
sfphinkterMC's Avatar
i believe there is a Bosch BOV on standard Comptech kit, its vented back to intake for CARB compliance so you don't here it. You have to weld on flange to fit most other BOV's
i would weld on at different location and block off original hole, that way you could test, switch and test performance of each(block new hole with original BOV in place also)
i had Vortech BOV with FMIC...sounds just like a turbo.
note: someone please correct if this is not accurate.
just bring to a turbo shop and see what they say.
Old Feb 27, 2004 | 08:20 AM
Jip69's Avatar
Aftercooled has a spot for a BOV
the non aftercooled does not have a BOV it has a bypass valve.
The bypass valve recirculates the air and u do not get the blowing off to atmosphere sound.
For the non aftercooled version I did not have the bypass valve installed and we plugged up the piping, and we welded on the BOV.
I will be at the shop later today and will have answers on if this works well or not.
JP
Old Feb 27, 2004 | 09:58 AM
wortham's Avatar
ya know, i'd be interested in hearing how it sounds. are there any sound clips out there to listen to?
Old Mar 1, 2004 | 04:52 AM
Jip69's Avatar
Sorry I did not get back to this post earlier, I have been busy all weekend. I got my car friday non aftercooled with BOV mounted to the pipe going from the blower to the throttle body and everything works perfect. I have no check engine light, nothing.
I can hear the BOV whenever shifting gears or if I rev it.
I can take videos and pics, but my videos play in quicktime. If you have quicktime and want to see th video PM me.
JP
Old Mar 7, 2004 | 11:43 PM
M-Type's Avatar
you got pm
LudeAtic
Jan 17, 2006 11:25 PM
Pok
Mar 22, 2004 10:59 AM
jayn
Feb 5, 2004 10:39 AM
Honda-S2000VTec
Dec 4, 2003 05:25 PM
Nobody
Sep 22, 2003 03:19 AM
