Comptech sc installed...but encountered a
Old Aug 16, 2005 | 07:21 PM
blackfx35's Avatar
Default Comptech sc installed...but encountered a
I accidentally over oiled the filter and it dripped all over the engine bay...would this cause any harm? It seems okay now that the oil dripped...
Also, the aftercooler is hitting the hood and I can not seem to find a way to lower the aftercooler. I can still gently close the hood and it doesn't rattle...does anyone else have this problem?
Other than that...my car runs flawlessly.
Old Aug 16, 2005 | 09:32 PM
folex187's Avatar
Did you buy the kit with the aftercooler or did you add it on? I had a hood clearance issue at first and I had to rotate the blower angle a little until it cleared.
Is it normal for the aftercooler to sit against the blower mount?
Old Aug 16, 2005 | 09:39 PM
Silver S2k4's Avatar
the AC should be touching metal with the blower.
Old Aug 16, 2005 | 09:44 PM
folex187's Avatar
I'm talking about the bracket that the blower is mounted to. Is it normal for the back to touch it?
Old Aug 17, 2005 | 01:20 AM
S2000_Europe's Avatar
this pics may help you
Old Aug 17, 2005 | 06:48 AM
xviper's Avatar
People have been spilling oil in engine bays since the dawn of the internal combustion engine. As long as you didn't spill much on the drive belts, all that will happen is that dirt, dust and crap will be attracted by the oil and your engine will get dirty faster. If you're worried about it, wait till the engine is cold and connect your garden hose to the HOT water tap and gently hose it down. The hot water will carry the oil away.
As for the A/C hitting the hood, you have two choices.
1. Adjust the latch assembly and rubber hood bumpers so the hood is raised slightly when closed.
2. Loosen up the clamps on the connector hoses between the A/C and blower and A/C and TB. Grab the A/C and twist it clockwise (as you are looking at it from the front). There should be a little leeway here. Once you've moved it (maybe up to 1/2", hold it there and tighten all the clamps up. Now see if the hood touches anymore.
Old Aug 17, 2005 | 07:45 AM
blackfx35's Avatar
I already raised the two rubber stops on the hood...
Anyways, I'm not going to worry about it as it's very minimal...thanks.
s2000-18
Mar 7, 2012 08:45 PM
S2000_FUN
Mar 27, 2009 03:47 PM
juice04
Mar 30, 2007 03:23 PM
Darien1629
Apr 15, 2005 08:36 AM
gregstevens
Dec 7, 2000 03:03 PM
