Comptech SC on MY04
Old Dec 19, 2006 | 12:34 PM
SC-SUZUKA's Avatar
What size pulley for AP2 to see 11-12psi?
Old Dec 19, 2006 | 01:42 PM
bc02's Avatar
remember your stock map sensor only reads to approx....11 PSI.....so an AEM 3.5 bar MAP sensor is a must over that....and you will have to tap the intake manifold to install it.
also i would not push more than 12 psi on the stock head gasket.....hope you have a good tuner and an AEM EMS...i just got mine installed and am awaiting a tuneing day....good luck
Old Dec 19, 2006 | 01:51 PM
SC-SUZUKA's Avatar
How may PSI's are you running? please keep me posted due to the fact that you are a AP2.
Old Dec 19, 2006 | 02:03 PM
bc02's Avatar
I have 2 pulleys i am going to try.......1st i am going to get a baseline with the ASP 3.5 inch pully.....its supposed to run 9 PSI but mine AP2 turns 9k rpm.....so i have been told it will now push close to 11 PSI at 9k.....so i am going to have to wait and see what happens on the dyno......i have a great tuner which has tuned tons of different cars with the AEM EMS so he is going to watch things close.....i also have a 3.15 in ASP pulley too.....we may wait for a 2 mm head gasket untill we install it....i'll keep you posted
Old Dec 19, 2006 | 07:45 PM
ATOice's Avatar
I would not push more than 10 psi on stock head gasket from the research I have seen on here. No specific threads, but search and I think you will see it. Also, depends on how much you get to redline to get your full 12 psi.
Old Dec 21, 2006 | 08:55 AM
batikan's Avatar
if you wanted 400whp, you should have gotten Vortech Kit...
Old Dec 26, 2006 | 07:56 PM
Silver S2k4's Avatar
I think you should get like a 3.25 or 3.30 pulley and with the headwork, raise your redline to like 8,800. You also need 750cc injectors and the AEM 3.5bar map sensor. Get it all tuned right with the right exhaust and you should be pretty close.
Old Dec 27, 2006 | 07:41 AM
C4SxM5's Avatar
you'll need a asp 3.0-3.1" pulley. i current have a 3.3" and got 9.6 psi @8200 rpm (ap2 also).
also, w/ 11 psi you may need to get headwork done and a GM or AEM map sensor.
Old Dec 27, 2006 | 07:47 AM
Don't go smaller than 3.25". I had a 3.15" and reached 13.4psi at 8,800. And that was logged at the map by the EMS.
Old Dec 29, 2006 | 12:40 AM
smirfs2k05's Avatar
sorry guys dont mean togo off topic
C4SxM5- by any chance did you dyno before/after with your DC header? I always hear DC headers lose power
BLanham
Aug 10, 2012 12:10 PM
freshs2k
May 18, 2007 10:15 AM
gochuxsaurus
Oct 13, 2005 09:46 PM
PanhandlingS2K
Dec 1, 2003 12:48 AM
S2peed
Nov 18, 2001 07:41 AM
