Comptech SuperCharger Install
Old Sep 27, 2005 | 06:04 AM
LonS2k's Avatar
Default Comptech SuperCharger Install
how's it going guys, im taking into consideration installing the supercharger myself. I would really appreciate anyone who has installed this kit before to share any knowledge that may be useful to me. Are the instructions that Comptech supplies adequate?
If running a tech2 7psi pulley what should your fuel pressure be at? Is there any tuning needed?
Old Sep 27, 2005 | 07:15 AM
73Zero's Avatar
When I installed my Comptech, this guide (along with the one Comptech provides) helped out a bunch: https://www.s2ki.com/forums/index.php?showtopic=175893
Also, if you're going to be running the 7 pound pulley, I would strongly recommend going to an experienced tuner in your area to have your fuel pressure adjusted.
Good luck with your install!
Old Sep 27, 2005 | 08:00 AM
XclusiveAutosports's Avatar
I recommend billman to do the install . I'm sure you can do it yourself but it seems like you are new to the S2000 and my not have that much experience with it. You can save a few bills by doing it yourself, so if you have the mechanical abilities then go for it. Also, you should consider the work involved in changing the clutch/flywheel also before starting to do it. Good luck with it
myflys2k
Southern Ontario For Sale
25
May 25, 2010 06:51 AM
nigaphan
May 22, 2010 12:21 PM
s2konroids
Mar 30, 2010 10:34 PM
gusrock77
Jul 7, 2006 09:31 AM
04RioS2k
Nov 14, 2005 09:29 PM
