comptech supercharger question
Old Apr 3, 2009 | 03:00 PM
NFRS2K83's Avatar
Default comptech supercharger question
ive searched everywhere... i just recently put on the supercharger with the 5lb pully i belive...
ive checked belt tension and everything seems to be good to go ...the only thing is the supercharger pulley is squeeling... and its really getting on my nerves.... anyone have a fix for this?
Old Apr 3, 2009 | 08:57 PM
dans2k's Avatar
^^^^I got the same problem before,The belt is loose. tighten the belt .
I end up running .5 smaller belt.It's repquire alittle magic.
Old Apr 3, 2009 | 10:54 PM
NFRS2K83's Avatar
i'll give it a shot... i thought the belt was tight enough... i didn't want to over tighten it because of the bearings and all in the sc... also if i spray it with a little bit of belt dressing... it goes away temporarily
Old Apr 4, 2009 | 10:02 AM
wonderd's Avatar
did you use ranch or cesar on that dressing?
Old Apr 4, 2009 | 10:07 AM
NFRS2K83's Avatar
thanks for the help i appreciate it
Old Apr 4, 2009 | 10:30 AM
s.hasan546's Avatar
Old Apr 4, 2009 | 10:39 AM
dans2k's Avatar
That's what I did,but with the WD-40. Just tight the Shizt of the belt,You wont break anythings with your hands and 14 mm wrench.
I'm running 3.2 pulley and end up using .6" available smaller size belt .
Due to the belt Adjustment already on the max available groove. I turned the engine over by hand for the belt fit into the pulley.
Now,I can see the boost all the way to almost 12psi.
GL
Old Apr 4, 2009 | 10:41 AM
NFRS2K83's Avatar
sweet thanks a lot man..
Old Apr 5, 2009 | 08:03 AM
nightcrawler7188's Avatar
maybe your tensioner pulley is loose also check that.
Old Apr 9, 2009 | 08:11 PM
wonderd's Avatar
anytime
nightcrawler7188
Mar 6, 2008 08:53 AM
s2kayo
Jul 28, 2005 02:52 PM
mikecl713
Sep 4, 2004 11:09 AM
Nobody
Aug 26, 2004 01:09 PM
