Comptech tensioner bearing?
Old Mar 23, 2012 | 07:40 AM
jdmdohcpower's Avatar
Default Comptech tensioner bearing?
I have an novi 1000 on my AP1 and I believe the tensioner bearing for the kit is on its way out. I thought that can be replaced locally. Anyone know what it is??
Old Mar 23, 2012 | 09:35 AM
Incase anyone else needs, its Napa part # 38015
http://www.napaonline.com/Catalog/Ca...015_0158698067
Old Mar 23, 2012 | 10:03 AM
s2000Junky's Avatar
I couldn’t find an exact replacement locally when I needed one, but I did find one that was slightly bigger (went from 3" to 4" I believe) which worked fine. Just throws off the belt sizing slightly.
Old Aug 5, 2013 | 04:25 AM
CoolGuy094's Avatar
Sorry to bump an old thread, but thank you OP for your research, finding this part number, and taking the time to come back and post it here for guys like me to find through search. You're the best!
I have my fingers crossed that the high pitched squeak/squeal I have right now is the tensioner bearing going out. Going to remove the tensioner and see if the sound remains. If it doesn't, then I'll get this new tensioner pulley. If it does, then FML I'll pull the blower and send it off to be rebuilt somewhere.
Old Aug 6, 2013 | 06:13 AM
CoolGuy094's Avatar
Removed my tensioner last night and it seems to have gotten rid of the noises I was hearing. Took the tensioner pulley off the bracket and the bearing definitely has some slop in it; you can hear the ball bearings rattling around if you shake it (like a maraca, lol). Picking up the new tensioner pulley from Napa this afternoon.
I think I need to go up one size on my belt too. With the tensioner completely off the belt is still tight enough to provide full boost at 13 PSI on a 3.4" pulley. I currently have a 370 belt, so I'm going to also pick up a 380 belt and see if I can get it to proper tension with the new tensioner pulley installed.
Old Aug 6, 2013 | 12:40 PM
kenta's Avatar
Just curious, did yours sound like this: tension pulley/bearing failing. Mine kicked the bucket after about a month of making that noise. Replaced it and it's been fine but the pulley was totally destroyed.
Old Aug 6, 2013 | 01:01 PM
CoolGuy094's Avatar
Not exactly... at idle mine was a bit of a high pitched chirp that occurred with every rotation of the pulley. But when I got up to about 4k RPM it started sounding a bit more like your video... At first I thought it was heat shield rattle or something similar. But after removing the tensioner both sounds have gone away. I can only assume that the sounds I heard were from the tensioner.
Old Aug 12, 2013 | 09:44 AM
Guys don't wait too long, if you hear that chirp change it out. My seized and shredded my belt.
Old Aug 13, 2013 | 04:09 AM
EOE's Avatar
EOE
Replace it. Mine was doa
Deception
May 30, 2013 07:54 AM
E4RTH WORM JIM
Oct 15, 2012 02:01 PM
RedSunS2K
Oct 7, 2012 07:20 AM
General Kratos
Jul 10, 2006 01:35 PM
payyourtoll
Jun 17, 2003 12:39 PM
