is my oil psi high or is this normal?
Built engine, 2.0, no oil squirters. 10w40 (as per Laskey's recommendation)
my oil psi sensor is located on a sandwich adaptor on the engine block. So it is measuring oil as it comes straight out of the block.
When I am just cruising around I am usually about 90 psi, it will sometimes spike over 100psi depending on load.
pics show me cruising at 4k rpms @ 65mph.
Does this seem normal to you guys?
