Comptech'd S2k... Engine bogging...
My '02 comptech S/C'ed S2k has been behaving badly lately...
When I punch it, it doesn't seem to want to "go"... It hesitates pretty badly, especially between 4-6k RPM's...
It seems to happen more in the higher gears for some reason...
I thought the clutch was slipping, so I had HTG's clutch package installed, but I'm still having issues...
I also had the MAF sensor replaced at Honda to the new design... Still having issues...
I'm not really sure what it could be?
Any ideas?
Spark plugs?
Belt slipping?
I don't really know where to look...
Thanks in advance...
-Matt
Any ideas?
Spark plugs?
Belt slipping?
-Matt
Originally Posted by xviper,Jul 28 2006, 03:00 PM
Go check and solder all your ESM wiring connections.
I had a shop install the Comptech...
Thanks,
Matt
Any ideas?
Spark plugs?
Belt slipping?
-Matt
Any ideas?
Spark plugs?
Belt slipping?
-Matt
Originally Posted by SiCK HONDA,Jul 28 2006, 03:28 PM
Where am I looking??
Thanks,
Matt
Thanks,
Matt
4-6K rpm is the point at which the MAP sensor begins to see boost. The ESM hides that boost from the ECU. If it doesn't get a good signal across those connections, the ECU may not see a signal at all or sees boost. That results in what you witness.
