Coolant lines off factory oil plate
What to do with the coolant lines off the factory oil cooler. Im going to be installing a oil relocation kit but looking cap off coolant lines if possible.
Well I had that in mind to connect the two together, but was just wondering if I could just get rid of the metal tube in front of the motor and just take a plug and block off the one that comes right out of the block. Was just wondering if anyone else has done this ?
Go to the auto parts store and pick up two 5/8" rubber hose caps. Then you can remove the entire metal tube. Will you have to remove the alternator to get to the hose off of the water pump
