Coreys Tuck/Shave project
Yea, that's just what the instructions say, it also says to install the head then the studs, I was under the impression I could install the studs into my block now and get those torqued down and set then just slide y head over the studs and then torque the bolts down?
Not to jack the thread. But i wanted to tuck the heater hose also. I have no a/c and only use the heat on occasion. Couldn't i just eliminate the heater valve completely and run lines to the heater core and back? So basically coolant would just keep flowing thru the core and when i wanted heat i can just turn the fans on.
It would still come through your vents as heat that way, like if you leave your heat off but the selector on hot, you can still feel a bit of heat passing through your vents, this would be constant without the valve
). So I had it hooked up exactly like you are talking about.As Corey said, heat will still flow out the vents. I found that it wasn't that bad with the top down, but when I had to drive with the top up it was very uncomfortable (i.e. HOT).
Honestly I would bypass the heater core all together rather than just eliminating the heater valve. Yes you would lose the ability to heat the cabin, but you could remove the upper and lower coolant bypass hoses/pipes and clean up the bay a bit.
Scott-
