ctsc 12psi dyno
just got back from the dyno.it is a dyno dynamics but he had it set with 15% correction to mimic a dynojet.car made 361.6@12psi or 306@12psi .post the dyno soon
mods
stock motor/compression
megan header
70mm test pipe
greddy 70mm single
ricks pullies
ctsc@12psi
4.77's
550 injectors
greddy emanage ultimate
vtec is lowered to 4500 or so i have it turn on as soon as it sees positive boost
update new quarter mile time slip
mods
megan header
70mm test pipe
greddy 70mm single
ricks pullies
ctsc@12psi
4.77's
550 injectors
Originally Posted by RAIN H8R,Oct 2 2009, 05:11 PM
Your posts are not very..informative. List full mod list and specs of yoru build please.
BTW, Im also at 361whp on a dynojet with stock header, 60mm test pipe and a modified CR catback.
no im revving to 9000 the dyno rpm must be off.max torque was 215 so we pretty much have the same numers.do you have a dyno sheet posted rain?yes the injectors are pretty much maxed out.yeah i have to shift to 5th when i go to the track but that run was on a very hot day without the intercooler.hopefully my step dad will take my car to the track tomorrow and run mid 12's.my best run that day was 13.0 and he went 13.1 so he as good if not a better driver than me.
