CTSC AfterCooler alternative
Regarding the secondary air pump -
I unplugged the hoses from it, removed them, and put a filter on the valve cover. No CEL, but the pump is very loud on a cold start.
Just leave the pump there and plugged in until you go stand alone.
I am not sure it would work... I want to say that the CT and SOS aftercoolers are angled down from the throttle body, to clear the radiator fan housing. This one appears to come straight out from the TB...
Just my $.02 from the pic.
John
John
interesting point jwa, the alternative is 11" long. how long is the comptech? hopefully we could get away with a 45 degree coupler or something to avoid the fan housing if it poses a problem.
i think i may order the kit, i just ordered a new flywheel and clutch from inlinepro today and it'll be here by next week (and a week later i go on a local vacation). so, i'll have to yank it off anyways (the supercharger assembly), so i'll be able to play around with the alternative water-air cooler and see what the quirks are.
You should not have to remove the SC or Aftercooler to do the clutch/flywheel. Just need to drop the engine subframe (motor and all) a few inches to get the bell housing clearance from the firewall.
No need to take off anything other than the exhaust/IC pipes (but the upper starter bolt will be a bit of a pain with the stuff in the way, but can be gotten to). Not sure if the blower would clear that front cross-member that runs across the engine bay (I think the SC sits above it).
I am turbo, so this is all from memory / second hand knowledge...
John
John
John
John
John
John
Originally Posted by tightcrap7,Aug 4 2009, 01:10 AM
I just noticed that there is no spot where i can mount a BOV. Will that be a problem? compression surge??
RunUrAss
Aug 14, 2009 06:04 PM
honda9krpm
Sep 11, 2003 03:06 AM
