CTSC with test pipe
Old Jul 25, 2007 | 03:32 PM
Irace4Kimchi's Avatar
Default CTSC with test pipe
how many people running only SC and have TP?
stock eveything.
stock comptech pulley.
will it be ok to add TP?
if itll require tune i wont bother to install TP.
only mod ill have is CTSC.
thanks for reading.
Old Jul 26, 2007 | 04:27 AM
bimmerpowa's Avatar
stock eveything.
thanks for reading.
You are perfectly fine putting a test pipe on and will definitely not need another tune. You probably will not notice any HP gains but will notice a better exhaust note and smell some unburnt fuel
Old Jul 26, 2007 | 04:40 AM
s0rted's Avatar
When I had a stock setup (minus plx R500 datalogger) and installed a testpipe i noticed that my afr's went up by 1 -1.5 points. At the very least I'd suggest you have a look at your AFR's and adjust the FPR accordingly.
Old Jul 26, 2007 | 05:46 AM
PeanutButter's Avatar
Dont listen to this guy.
You install a test pipe on an s2000 with a comptech SC you will go lean
Old Jul 26, 2007 | 06:22 AM
bimmerpowa's Avatar
My AEM AFR on my dash stayed the same after I installed my test pipe...maybe yours was just different?
Peanutbutter - anyway you can back up this statement? I searched on the forums before I installed mine and no one had issues of it before.
I find it odd now that when I posted a thread in concerns to installing a test pipe everyone said it would not do anything and I would be fine and the cars ECU would adjust accordingly. Yet now when I relay this information on, everyone says the opposite. I guess this is a forum and everyone does have their own side and/or we have mismatched information/data.
After I installed my test pipe my AFR never changed, and I am constantly watching that on my dash.
Old Jul 26, 2007 | 06:49 AM
thanks for the comments people.
see this is why i posted about this... bc i remember "reading" few peoples post and saying going back to stock cat after they had TP on their SC'ed S. cant find that thread anymore.
so its like 50% of people will say its ok and 50% will say no.
well i dont know thats y im asking =)
thanks again for reading!
lets hear more opinions!
Old Jul 26, 2007 | 06:57 AM
stphotographer's Avatar
Thats because every engine and CTSC install is different. Better be safe than sorry, get a AF reading or get on a dyno if you install a test pipe.
Old Jul 26, 2007 | 07:11 AM
WashabiS2K's Avatar
installing a testpipe more than likely makes the car run leaner, especially with the addition of a supercharger. i just had my supercharger installed last thursday and put in a t1r with tp the next day.. i babied it down to the tuner where i got it tuned and now i can run the car safely im not sure how it would respond with the stock exhaust though, but best bet is to be safe and get the AFR's checked before you go out mashing the throttle.
Old Jul 26, 2007 | 07:31 AM
S20004ME_PDX's Avatar
I got the CTSC with the Berk TP. FPR was adjusted to run richer for the TP.
Its just better be safe than sorry.
Old Jul 26, 2007 | 08:24 AM
lend_type_R's Avatar
on the lean side ive read if you go beyond 12.5 is pushing and on the reach side of the tuning, that will run safely after the install and before going for the tuner how reach can we go? is 10 AFR way too reach that itll damage the engine if is bein driven for an hour on the way to the tuner? i also run on a 70mm T1R exhaust and testpipe.
