CTSC with test pipe
Mine went lean a point also. I have a before and after dyno, I picked up 15-10 whp midrange with the test pipe.
You want to be about 12:1 full throttle to be safe at stock boost levels. 12.5:1 if you want a bit more power. From my experience CTSC comes lean out of the box no matter what Comptech says.
i was running 11.5psi on my Comptech SC and when i installed a test pipe, it jumped up to 13psi
i am quite sure that even with a stock set up, you will run lean when installing a test pipe..
In, clockwise. The adjustment screw is for fine tuning only. It may not be enough to get your a/f safe. If you fiddle with the screw to much, you could through off the internal adjustment preset from Comptech and break the fpr.
jean-roch
Feb 20, 2013 04:04 PM
