CTSC w/ AC
Old Jun 27, 2008 | 04:30 PM
ekallstar21's Avatar
Default CTSC w/ AC
Im getting my CTSC w/ AC and T1R 70r-em exhaust w/ 70mm test pipe installed next week.
I'm going to be running stock boost so would it be mandatory to run some type of engine management. I know its not ideal but i have a vafc 2, would it work????
Thanks
Old Jun 28, 2008 | 05:45 AM
mikey k's Avatar
It may well run a bit lean with the exhaust and decat.
Not sure VAFC2 will sort that out.
IIRC the OEM ECU eventually overides it.
I ended up putting the cat back and tweaking the FPR on a dyno.
I will end up putting an AEM EMS 1052 in over the summer.
Old Jun 28, 2008 | 09:15 AM
5power's Avatar
I was lean with just exhaust. Here is my recent post. I think you will go lean but who knows?
https://www.s2ki.com/forums/index.php?showtopic=607385
Old Jun 28, 2008 | 09:35 AM
tbtak's Avatar
IMO, a tuner can do more with getting the most out of your SC with a AEM EMS.
Old Jun 28, 2008 | 10:43 AM
nightcrawler7188's Avatar
the VAFC should be adequate if you're running stock boost or anywhere up to 7psi. i have header/tp/exhaust on my CTSC/AC @ 7psi and it's been running great for almost 6 months now..tuned with just a Neo (same as VAFC, just a newer version) and stock injectors. of course EMS would be 10x better, but for what you have, VAFC will do just fine from my experience.
Old Jun 28, 2008 | 10:48 AM
RISLAR's Avatar
Thats what ive got and i've not had any problems so far!! Dont think i would bother with the VAFC unless if you havent got a good tuner.
Old Jun 28, 2008 | 12:07 PM
thx for the help guys
turtlepower
Nov 11, 2012 01:49 PM
REVZ TO9
Mar 28, 2007 07:05 PM
krazyguy316
Aug 25, 2006 11:54 AM
icemans2k02
Jul 3, 2006 05:12 PM
Hamiy
Apr 23, 2005 05:37 PM
