ctsced s2k on 8psi
Old Jan 23, 2010 | 11:09 AM
chorne1787's Avatar
Default ctsced s2k on 8psi
ok so have the comptech s/c and i want to run 8 psi first off what size pully is the 8 psi on a ap1 kit and 2nd is 8psi safe for a stock s2k other then a stage 2 clutch and exhaust and a tune on e manage ultimate thanks very new to forced induction so sorry for newb questions also i did search i just couldn't find anything
Old Jan 23, 2010 | 11:57 AM
Deception's Avatar
most will say its all in the tune
Old Jan 23, 2010 | 12:33 PM
Tyraid2K's Avatar
the answer is yes, i run 10psi turbo on a stock motor
Old Jan 23, 2010 | 02:59 PM
nsx_bob's Avatar
yes you will be fine.
if you want, you could run meth to be even more safe.
Old Jan 23, 2010 | 05:24 PM
ILOVEMYAP2's Avatar
i ran 12psi all stockbut i was tuned
Old Jan 23, 2010 | 06:34 PM
s2k aok's Avatar
aftermarket fuel pump is necessary (if you don't already have it)...
Old Jan 23, 2010 | 07:14 PM
1nate7's Avatar
4" pulley and you will need larger injectors as well.
Old Jan 23, 2010 | 08:17 PM
chorne1787's Avatar
already have a walboro and i don't have aftermarket injectors but i was under the impression that stock injectors could handle 10 psi on the greddy turbo so why would the supercharger need upgraded injectors i know they will be at there max duty cycle but i don't plan to go any higher for a good while
Old Jan 23, 2010 | 09:08 PM
ILoveMYHonda1984's Avatar
This guy's english hurts my head...
Old Jan 24, 2010 | 12:18 AM
s2000Junky's Avatar
You can get away with 8psi with stock injectors. Yes the injectors will be reaching max duty, they work but its not ideal long term. Besides, in your case with already using a device that can run aftermarket injectors such as the emanage, it doesn't make sense not to.
If your staying at 8psi 440's will be much more sufficient. I have a set for sale with pnp clips if your interested.
