Custom Intake for SOS supercharger
Old Feb 7, 2014 | 07:21 PM
CoolGuy094's Avatar
Originally Posted by APoner
I left the intake in the regular spot. What i did was duct cool air to the filter via one of the side gills on the bumper. I found the flex pipe and all the parts i needed at pepboys for like $25
I can post pictures later
I did the same exact thing! Dude, our setups are so similar its scary. I think we have some kind of brainwave connection.
Old Feb 7, 2014 | 08:19 PM
s2k manic's Avatar
pondering a cold air intake just made a heat shield for my comptech airbox just a piece of aluminum that goes next to the radiator and bolts to the egde of the airbox I figure less heat will get pulled in will see
Old Feb 8, 2014 | 06:15 AM
APoner's Avatar
Look familair?
Old Feb 8, 2014 | 06:54 AM
CoolGuy094's Avatar
Lmfao, you tell me.
Old Feb 8, 2014 | 07:13 AM
RAIN H8R's Avatar
I cant see that kind of intake setup doing much compared to relocating the filter to the wheel well.
Op, your on your own for find the hoses. All i remember is buying the hoses from a semi truck styler retailer online from washington state.
Sent from my Samsung Galaxy S4
Old Feb 8, 2014 | 07:15 AM
APoner's Avatar
I used a 3" hose. I had to cut a piece off my headlight bracket to route the house behind the light. Looks good!
Old Feb 8, 2014 | 07:23 AM
APoner's Avatar
My only fear of relocating the filter is losing some air velocity and flow. Im sure is better but this works well believe it or not.
I did a crude experiment and put a thick wire over the end of the duct. After a spirited drive with a pretty cool ambient temp the wire at the end of the duct was cool to the touch.
Being skeptical I taped the end and went for another drive. The wire was warm. I also noticed .2-.3 bump in boost on really cool days where as before in same temp i would always be at 6 - 5.9 psi.
Maybe just coincidence. I think it helped at the very least drawing cooler air to the filter at speed.
Old Feb 8, 2014 | 08:45 AM
donaldmejr's Avatar
I made my own...just search my name and you will find my upgrade thread with all the details.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Old Feb 8, 2014 | 01:15 PM
CoolGuy094's Avatar
Yeah I think mine is a 2.5" hose instead. I've been meaning to do a similar test to see if it actually is beneficial. I bet it does reduce heat soak on the filter area and reduce IAT's a bit.
Old Feb 12, 2014 | 08:34 PM
cheddaboy's Avatar
is the one fan ok or do you need both?
