.........CV Joint cups again
Old Nov 7, 2010 | 12:41 PM
JoeyBalls's Avatar
Thumbs down .........CV Joint cups again
For the second time I am going to have to swap out my CV joint cup things. I guess being lowered and the added power made a new indention so anytime the car is under load, it vibrates violently, like the car is going to come apart. I already swapped the cups so what are my options? Can I get like spacers for the cups or just by the cups themselves?
thanks
Old Nov 7, 2010 | 12:48 PM
DFWs2k's Avatar
There's a place up your way that sells whole remanufactured axles for $60-80, id just get those, someone posted a link in my thread where I popped an axle, wish I knew someone up there to send me some
Old Nov 7, 2010 | 12:53 PM
Jacko's Avatar
Actually I think mine are done too I noticed it just prior to blowing the head gasket and since you posted I just remembered another thing added to the list.
Old Nov 7, 2010 | 12:56 PM
JoeyBalls's Avatar
^ yea, and it gets very bad quick , sucks donky balls And forget about going WOT the car shakes to the point where I feel like its about to explode
FML
Old Nov 7, 2010 | 01:01 PM
Jacko's Avatar
Yeah its starts off not to bad but doesn't take long to get REAL bad. I haven't done it yet but I assume its not that hard and doesn't take too long.
Old Nov 7, 2010 | 01:39 PM
JoeyBalls's Avatar
^ Yea I swapped the right to left about 2 years ago, I did it with the axle still on, I had bloddy knuckles for weeks. Hoping Jeff can do it this time, I just need to know where to get the parts. Hopefully I can just get the cup
Old Nov 7, 2010 | 02:34 PM
TRBOKEV's Avatar
Get some driveshaft spacers.. I had the bad vibration and switched in some t1r spacers and the vibration has been gone for 15- 20k miles now.
Old Nov 7, 2010 | 02:44 PM
jaundice's Avatar
In the wheel and tire section there's a sticky about spacers for lowered cars. U should check it out.
Old Nov 7, 2010 | 03:24 PM
JoeyBalls's Avatar
Ok, I heard the Spacers have a habit of failing and causing catastrophic crashes blah blah. Am I mistaken?
Ok, I found E-Bay Drive Shaft One peice spacers for 100.00 I think I am going with these. I can probably re-use the OEM bolts right? I figure the spacers dont really take much abuse, they are aluminum so I should be ok? I dont want top spend the money on new CV cups, they are very expensive
Old Nov 7, 2010 | 04:04 PM
Jacko's Avatar
I don't know if I understand why the spacer would prevent the CV cups from wearing ? I feel like it has more to do with having the power we have and then doing 4th gear pulls every time I drive
