Dck's Turbo build thread
Old Jul 11, 2013 | 04:10 PM
Dck's Avatar
Dck
Default Dck's Turbo build thread
Just finished acquiring everything for stage one of my turbo setup
so heres what i got so far, keep in mind it will be upgraded later,
and that i started with a used kit from another member here on s2ki
turbonetics 60-1 .70ar/.48 60 trim comp. wheel
custom front mount manifold
2" stainless steel IC piping
3" custom downpipe
Invidia Q-300 duals
Inlinepro FMIC
Tial 38mm wastegate with 10.6 lb spring
dump tube vented to atmosphere
Mac boost solenoid
HKS sequential BOV
ID1000 injectors w/ OEM o-rings
walbro 255 fuel pump
Haltech platinum pro PnP ECU
AEM AFR gauge
AEM boost gauge
oil cooler setup
competition clutch stage 2
looking to hit about 350whp anything higher would be cool but not lookin for over 400 till i upgrade the rear.
install starts tomorrow, should have it at the tuners by the end of next week.
if i am missing anything let me know,any advice or tips are welcome as well as this is my first time with a turbo.
Old Jul 11, 2013 | 04:21 PM
d-bo's Avatar
i can't tell if your car is an ap1, or an ap2 with ap1 headlights
but make sure you change to the 02+ oil jet bolts if you have an ap1 my00-01
Old Jul 11, 2013 | 04:28 PM
herecomesboost's Avatar
Why'd you decide to go with 2" stainless steel piping (as opposed to 2.5/3" aluminum piping)? Just curious. Good luck with your build. In for pics
Old Jul 11, 2013 | 04:29 PM
Dck's Avatar
Dck
MY01, just the bolt itself or the whole small bracket with the curved piping?
the kit i bought came with it, my tuner said it was fine for now as long as im keepin under 400whp.
Just the bolts themselves
i will check this out, wouldnt happen to have a part # would you?
Old Jul 11, 2013 | 04:34 PM
d-bo's Avatar
Old Jul 11, 2013 | 04:44 PM
Dck's Avatar
Dck
so they just went from a 2 hole to a 4 hole bolt, could i just drill another hole thru makin it a 4 hole design?
Old Jul 11, 2013 | 04:47 PM
d-bo's Avatar
i wouldn't advise so
check out cheaphondaparts.com or hondaautomotiveparts.com
part # is 15290-PCX-000
Old Jul 11, 2013 | 05:04 PM
cuci591's Avatar
You will be pushing the limits of the stage 2 clutch so I would start saving. Or even better get it out of the way now and push it to 400. I hade a similar setup when I first started and it made 400 just fine 2" intercooler piping and all at about 14psi.
Old Jul 11, 2013 | 05:06 PM
Dck's Avatar
Dck
i will order these tomorrow when the honda dealership is open next to my house.
from what ive read so far is these are a must in any MY00-01.
Old Jul 11, 2013 | 05:27 PM
watch0bak's Avatar
I'd say stage 2 is good enough for you, even at 400whp. I have stage 2 at my current power 445whp/327trq and its holding just fine.
